Camaro DIED!
Old Sep 21, 2003 | 11:21 PM
Jaswir's Avatar
Angry Camaro DIED!
i was drving home and i was doing about 55-60 and all of a sudden just went dead! Its like i turned off the car while rolling! no noises or anything... i pull over and i see some smoke come out from under my hood but very lil... i try starting and sounds like it normally does when i try to start it but just wont turn over... i have been told it could be the fuel pump or the timing chain??? just wondering if anyone has any ideas! thanks for any help
btw its a
1988 Camaro RS 2.8L v6
oh and about 3 weeks ago at high speeds it was chuggin like it wasnt getting any gas thats why i think its the fuel pump?
if you look down some more in this forum i posted about it
well thanks for any help
Old Sep 22, 2003 | 12:49 AM
94m5's Avatar
Can you hear the fuel pump running when you first turn the key over right before you start it? (slight humming noise comming from the fueltank) If not, that's your problem. You mentioned smoke comming from underneath the hood. This is'nt a good thing because that could mean you've blown something, like a chain or a gasket, OR it could be something as trivial as blowby comming out of the crankcase. I would run with the fuel pump idea first, and if that does'nt work, Start on the engine internals.
Hope this helps, If not, It's late and I'm going to bed.
Old Sep 22, 2003 | 01:02 AM
Jaswir's Avatar
yes you can still hear that humming noise i always thought that was my motor for the trunk making sure it was closed but i dont know im going to take it to a shop wednesday
Old Sep 22, 2003 | 02:36 PM
camaros_4_lfe's Avatar
prob somthing electrical most likely
Old Sep 24, 2003 | 11:42 AM
cabell84's Avatar
The same exact thing happened to me in highschool. My 1986 firebird just died. I changed the fuel filter and it ran perfectly after that. Before it died, it chugged a little, like you described. If i were you, id change the fuel filter before you take it to the shop. Even if that ends up not being the problem, its cheap. Just my two cents.
Old Sep 24, 2003 | 04:47 PM
Jaswir's Avatar
i did that when it first started to chug 2 weeks ago... now i really think its the timing chain... well my buddy is coming over today to look at it
Old Sep 27, 2003 | 06:04 PM
Jaswir's Avatar
found the problem the spark pluggs were getting no spark,,, it was the ignation coil... so a simple cheap part and really easy to install... thanks tho for your help...
A's 91 Z28
Jan 11, 2015 10:58 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
ModdedNerd
Dec 18, 2014 10:52 PM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
