Brown sludge in my coolant
Old Mar 13, 2012 | 01:31 PM
Mevissen's Avatar
I have a 1999 camaro with the 3.8 v6 with 122,000 miles and it runs great! But I'm just taking it out of storage and checking everything over and I noticed that the coolant is brown sludge. The car never overheats and runs awesome but I want to figure out this problem... Anybody know what is causing this? I have read online it might be my trans cooler lines leaking in the radiator, or it's a blown head gasket and it's oil leaking in there. It doesn't smoke white or anything. I need help
Old Mar 13, 2012 | 02:17 PM
Joe Bellman's Avatar
Re: Brown sludge in my coolant
If the trans cooler was leaking into the radiator, it would be red and floating on top for the most part. I have had this problem before - buy and install new radiator. Do not drive until that is done because you can get coolant into the transmission which is not good.
A blown head gasket will sometimes let water into the oil. Is the oil normal looking? A compression check would reveal more info.
I would start off my flushing the coolant system.
Another thought, the previous owner may have had a minor leak and put stop leak in there. It works but makes the coolant look bad.
Old Mar 13, 2012 | 02:41 PM
Mevissen's Avatar
Ok thanks! I will flush the coolant system tonight. The oil looks fine and there is no water in it. I was hoping it wasn't the head gasket.
Where can I get it a compression test? Dealership?
Old Mar 13, 2012 | 02:59 PM
greenformula94's Avatar
any shop can do a compression check, and there are ways to do it at home aswell
Old Mar 13, 2012 | 06:04 PM
advance auto has a tool rental program, usually free. pick up a compression checker there.
Old Mar 14, 2012 | 01:45 PM
Mevissen's Avatar
Smile Re: Brown sludge in my coolant
Ok I'll have to get it checked. Thanks for the help!
Old Mar 14, 2012 | 01:51 PM
red97rs's Avatar
its just the dex-cool. mine did the same thing, after sitting for about a month... i just flushed my radiator and refilled with 50/50 dexcool/water.
Old Mar 18, 2012 | 02:24 AM
ImportKILLER's Avatar
Yup, it's the DexCool.
If it's old, it's time to change it out anyways. But if it's fairly new, that means there is a leak somewhere that is allowing air into the system. DexCool is very sensitive in that respect and it turns DexCool into the brown sludge. Check your reservoir dipstick, it's likely gunked up too.
If this is the case, you'll need to try to find the culprit and then flush and fill the radiator a few times until it comes out clear and then refill.
Old Mar 19, 2012 | 09:40 AM
whitdog54's Avatar
Probably have a slight lower intake manifold gasket leak too.
Old Mar 31, 2012 | 02:37 PM
Evolution223's Avatar
i would say having a little sludge on the dipstick is probaby normal if the coolant is a few years old, I religously have my coolent changed before 5 years.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
