bought car with siezed 3.4, which route to go?
#16
There's a good bit you can do to a 3.4, lots of stuff available at FTPP.net
I'm using the Comp Cams 260H, nice streetable off-the-shelf cam, 1.6 rockers give it .470 lift and a little more than the advertised 212 duration. Stock cam is .390/.410 and 195/201.
You can get a basic tune at fastchip.com or just go with a Jet Stage2 module. Also any of the LT1 intakes will work on the 3.4 and the cat-backs are very similar as well.
I tried 19# injectors from a 3.8 but they ran too rich, had to put the stock ones back in.
#17
#18
forgive me for being dense, but how does an Lt1 intake work on a 3.4L?
thanks. I think i'll probably do something like the setup you mentioned. sounds like a decent way to have some fun, yet stay pretty close to stock.
I did a little more research and noticed that in 1995 the camaro came with the 3.4L or the 3.8L.... So, since i'll be getting a junkyard motor anyway, can't i just put a 3.8L from a 1995 camaro in it, and just buy the wiring harness and computer to go with it?
#19
Cold-air intake. The LT1 and 3.4 can use the same one. Just look up the part # for the K&N FIPK. Or any other brand for that matter. Moroso, SLP, etc. The 95-97 3.8 can also use any of the same intakes but you have to get a rubber elbow to use with it. The LT1/3.4 come stock with the 90° elbow.
You could try the swap, I've never heard of anyone attempting it before. 94-95 3.4 share the same ODB-I PCM and the 3.8 is ODB-II so I don't know if the harness will mate up. Pretty sure the trans housing is different, I know 3.4 uses an external slave and the 3.8 T5 has it internal. Not sure about the K-member, I know the 3.4 is different than the LT1. The 3.8 has 2 fans. That's all the differences I can think of for now.
#21
http://www.gmtuners.com tunes the PCM for 3.4 and 3800 and 3800 OBD1
#23
how do they tune the 3.4L PCM? on my car w/ the LT1 we plug in the laptop and tune it while driving. I figured it was the same for the v6 cars. anyone know how much fastchip.com costs?
#27
....18 year old kid, doesn't have his license yet, never had a car... NOT getting 275 hp to kick around! IMO... i would love to have had nearly 300 ponies when i was 18, however if i did.. i probably wouldn't be alive today to tell you about it. we're gonna toss a boneyard powerplant into it. at this point i was just trying to decide if the 3.8L would work since it's gotta get a new motor anyway. it seems that it would be a lot of hassle SO.. it's going to be getting the stinky little 3.4 yay. i told my brother already that we're doing the 3.4 and he was a little heartbroken to find out that he would have a car about as powerful as my Bonne but he'll get over it. we're going to make it look really sweet to compensate for the fact that it will have little to no guts.
everyone who has contributed ideas and information here have been very helpful. I have always appreciated the thoughts of this community since I joined in 2000.
#28
call me whatever you want.. but i might end up going back on what i said about doing an Lt1 swap into this car IF, and only IF i can get this engine. I found an engine trans and computer for probably cheaper than i'd ever get the v6 for.
so how crappy is it to change the dash harness.. that's the only thing i really cringe at is taking the dash apart. are there any online directions that make it easier?
the swap would be from 1995 3.4L m5 to 1995 5.7L A4. lots of garbage going from manual to auto i suppose as well
input?
If i can't get the engine as cheap as i think i can, i'm still going to just put a 3.4L back into it
input?
#29
Check out www.v6conversion.com for details on all the parts you'll need to go to the LT1 in there.
