View Poll Results: BOSCH +4 Platinum Spark Plugs: Yea, or Nay?
YES! Definetly
0%
NO! Not at all
78.57%
YES & NO (see reply)
7.14%
I dont know... You're SOL
14.29%
Voters: 28. You may not vote on this poll
BOSCH +4 Platinum: Yea, or nay?
Old May 11, 2006 | 02:17 PM
  #16
hot white z's Avatar
Re: BOSCH +4 Platinum: Yea, or nay?
what if you ran a hotter plug? would you get a better burn?
If the only thing you did was change to plugs with a higher heat range, probably not. More voltage to the plug, optimal quench area, sufficient turbulence of the air/fuel mixture, grade of gasoline, timing, not running too rich or too lean, etc... all are part of a "better burn".
Old May 12, 2006 | 03:31 PM
  #17
PaganEgyptian's Avatar
Post Re: BOSCH +4 Platinum: Yea, or nay?
My experience with Bosh P4's in 2003 are bad. The plugs were wet with fuel when I removed them. I had a good A/F and I had very good voltage to my plugs. I learned of NGK V-Power plugs and used them spring 2004, I will never use anything else. I started with Tr-55's as they are stock heat range, after a PCM tune with lots of Timing advancement, I switched to TR-6's gapped .070 and love them. -Tim
Old May 13, 2006 | 04:04 AM
  #18
user name's Avatar
Another vote for using what the application calls for. If copper plugs were OEM, stick with them. Plat doesnt conduct as well as (annealed) copper, so copper has the performance edge [of the two]. Copper will suffer quicker gap erosion, but if the plugs arent too hard to swap, it is of little matter.
Good luck.
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
BlackBowTie
Sep 6, 2002 03:11 PM
Black Sunshine/ 00SS
Aug 26, 2002 09:26 PM
wazup158
V6 Tech
Aug 20, 2002 11:23 AM
TheZ
N2O Tech
Aug 14, 2002 10:08 AM
