biggest possible engine
Old Mar 12, 2010 | 08:18 PM
martin15fox's Avatar
Question biggest possible engine
I bought a 2000 camaro, with a 3.8 v6....i was wonderin wats the biggest compatible engine i could put in it
Old Mar 13, 2010 | 12:49 AM
supercharged024's Avatar
Depends what your budget is. If you want to tackle a swap, an LS2 should be big enough(6.2liter).
Old Mar 13, 2010 | 07:56 AM
"Biggest" in terms of displacement? ..... horsepower? ...... physical size?
Will it be running normally aspirated, or with forced induction (supercharger, turbocharger), or with nitrous?
What is your budget?
The 4th Gen chassis will accept any of the LSx series of engines, so you could go with the Corvette 7 Liter Gen Z06 engine. Max factory HP would be the Corvette 620HP supercharged ZR1 engine. You can get aftermarket block that allow you to build a 454ci (7.4 L) LSx engine. Here's one from Mast Motorsport that makes 700HP, normally aspirated. (Follow links to "X-Block 454 SS"):
http://www.mastmotorsports.com/gascrate.php
You can also fit a Big Block Chevy in the 4th Gen chassis. Here's a 454 in an early 4th Gen:
http://my.att.net/p/s/community.dll?...pageid=28387&c
John Moss's put a 510ci big block 4th Gen.
Here's a 97 SS convertible with a 1,350HP Vortech supercharged 383 cubic inch Gen 1 SBC. Car ran low 8's in the 1/4-mile, at close to 170 MPH:
http://www.injuneer.com/images/photo.../DCP03825a.jpg
It did need the SS hood to clear the throttle body.
meissen
Jun 1, 2015 07:59 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
pecaspickles27
Wheels and Tires
Jan 20, 2015 02:31 PM
White98Z28
Sep 12, 2002 10:21 AM
firebirdude
Aug 7, 2002 07:31 AM
