Belt Squeal
Old Dec 16, 2010 | 06:24 PM
jeffrox13's Avatar
Question Belt Squeal
i have a 95 camaro 3.4L that recently started to squeal. I thought it may be the belt so i bought a new one. It stopped it for maybe a 2 or 3 weeks then it came back. There is a video at the bottom showing what it sounded like after the 2 to 3 weeks that it came back. But i was just wondering if it was ok to spray some Multi Purpose Lubricant on the belt. I already did and it has stopped the squeal. I dont know if i should have done that or not.
Here is the Lubricant--- MPL
Here is the video--- My Car
Old Dec 18, 2010 | 12:41 AM
Evolution223's Avatar
Re: Belt Squeal
you can buy a specific belt spray at an autoparts store, it will actually increase the grip of the belt to eliminate squeals,
I would think a muti purpose lubricant would only make the slipping worse, assuming the squeal was caused by slippage.
It sounds like you have too much friction in a pulley somewhere or your tensioner is bad if it squeals only after 2-3 weeks so you have another issue there, it may not be a big deal but you might want to take your belt off and check your pulleys for play or high friction and check the tensioner.
Old Jan 1, 2011 | 12:31 PM
Snoman73's Avatar
Re: Belt Squeal
i too have a 95 3.4 camaro, and it has been my experience that this is very common on these cars because of the Belt Tensioner Pulley. It has a plastic wheel. Replace it and it shouldnt squeal for a year or so, but expect to replace it about once every 12-15 months unless you can find a belt tensioner pulley that has the metal wheel, or try the spray like the other poster said
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
colts0455
Jul 7, 2015 07:19 PM
