any advice On spark plug wires rubbing against Manifold
i Have a few spark plug wires rubbing right on the manifold on the driver side. I have a feeling the manifold is going to burn straight through the wires and cause a big problem and th ewires all are just short enough where i can adjust then to move around the mainfold and i have no sheilds on the driver side.
any advice>
any advice>
Re: any advice On spark plug wires rubbing against Manifold
tie them up like this
http://www.ehow.com/how_4876807_loom...res-cheap.html
or you could use these
http://www.thermotec.com/products/14...e-sleeves.html
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
