97 camaro Headlights? WTF?
Old May 9, 2007 | 01:46 PM
Wishmaster's Avatar
how in the hell can I turn my headlights off when my car is running? Everything is freakin Automatic in this car.....alls I gotta do is get in and crank it and lights come....what if I wanted to crank it with out lights? hell I couldnt sneak up on anyone if I tried!...LOL
Old May 9, 2007 | 02:41 PM
Need4Camaro's Avatar
There's a way to disable it if I remember correctly... albeit I forgot, my 97 and 01 have the same thing, it doesn't bother me at all although it spoils me as when I drive another car sometimes I forget to turn the headlights on at night... ...What're you trying to sneak up on someone for? Maybe you've got the right car for your personality...
Old May 9, 2007 | 03:30 PM
Wishmaster's Avatar
LOL!!!...Im not trying to neak up on anyone...I was just sayin.....but like the other night when I was at the drive-in and I wanted to crank my car up to charge the battery and ...HONK HONK HONK!!!.....cause my freakin lights come on!....but yeah your right I love it that alls I have to do is get in and drive...but sometimes its good to be able to cut them off.
Old May 9, 2007 | 03:53 PM
2000GTP's Avatar
Its another one of those GM safety features, DRLs, Daytime Running Lamps. I agree with the above poster, there may have been a method of disabling them discussed here in the past, it may be worthy of a search.
Old May 9, 2007 | 03:58 PM
rickjames343's Avatar
If you click the Ebrake up 1 click, then crank, it should disable the headlights.
Old May 9, 2007 | 05:53 PM
dangalla's Avatar
yup that'll do the trick, if the car is already running pull it up one click n cycle the key off then on
Old May 14, 2007 | 05:42 PM
Pure_Camaro's Avatar
http://www.xse.com/leres/ss/drl.html
Here you go bro its how I did mine, I have a 1997 Camaro M5 But what I did was disconnect C2 and I dont have any problems besides the fact that I cant open my hatch with the key in the ignition.
Old May 15, 2007 | 08:45 AM
pcgamer4life's Avatar
I shorted out my DRL module on accident. I was in the same situation, wanted to be able to cut the lights off if need be. I pulled out the module and was going to put a switch to toggle between automatic, and selectable. However, I was about to solder in my lead wires and I jumped two solder points on the board and it shorted out the lights, so they stayed manual from then on.
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
Dec 4, 2014 11:56 AM
siguy
Nov 27, 2014 10:07 AM
Caps94ZODG
Sep 7, 2002 10:09 PM
