94 camaro
Old Oct 21, 2003 | 12:05 AM
kickinthehouse's Avatar
94 camaro
Car = 1994 camaro RS 3.4L SFI -Automatic Transmission
hey guys i have an issue when im on the freewway in Drive @80mph my rpms= 3000
What the heck thats a little high no?
also my gas guage seems to be off how do i fix that
also my low oil light will come on every once in a while when i start the car but when i have my uncle and all the other dudes on my block check my oil they say its fine and teh guys at brake masters whe n i got my oil changed said it was mkay 2
thanks in advance
Old Oct 21, 2003 | 12:09 AM
also the car shakes a bit at stop lights
Old Oct 21, 2003 | 12:55 AM
camaro6's Avatar
I think 3000RPM might be a little high for 80mph. I think i do 80 at around 2500 - 2700RPM. And for your gas gadge, it is probably working fine. Usually, the first 1/4 of the gas lasts a long time - 200 miles, then after that, it drops pretty fast. All 4th gens are like that, it has something to do with the way the gas tank is shaped i think. If thats what your refering as the gas gadge problem, then its probably fine.
Old Oct 22, 2003 | 12:36 AM
bump
Old Oct 22, 2003 | 02:29 AM
99blackSS's Avatar
You should get that checked out. If it's idling rough something isn't right, plus your RPMs are appearently a little high.
Old Oct 22, 2003 | 03:50 AM
how much is it gonna run me to get a mechanic to look at it ?
and im nto tallking like the mechanic next door like pepboys or soemthing
Old Oct 22, 2003 | 01:24 PM
99blackSS's Avatar
I know the dealer sometimes calls me before they fix something. I would take it to the dealer and clearly specify that you want them to call you after they have determined the problem. The dealership I take my car to also charges by the fix not by the hour so they wouldn't charge you to look at it. I don't know if all dealers work this way but my local one does.
Old Oct 22, 2003 | 04:11 PM
my camaro is a 94 would a dealer ship still wanna takea look at it ?
Old Oct 22, 2003 | 04:21 PM
99blackSS's Avatar
Of course. Go to the dealer and tell them what you have noticed and that you want them to call you before they make any repairs. Then when they call see what the problem is and how much it will cost to fix it.
Old Oct 22, 2003 | 04:40 PM
ImportKILLER's Avatar
3000 RPMs at 80 is way high.
At 80 it shouldn't be any higher than 2500...that is even a little high I think.
Old Oct 22, 2003 | 04:42 PM
And then tell them no thanks, I'll find another shop to do it for far less.
I really don't like the dealerships...especially for non-warranty work.
Old Oct 23, 2003 | 04:33 AM
quickie what should i be in on the highway Drive or overdrive ?
Old Oct 23, 2003 | 12:39 PM
99blackSS's Avatar
Overdrive for the highway. Use D for racing. If you get high enough in the race: put it in OD.
Old Oct 25, 2003 | 01:56 AM
Knight5's Avatar
first of all is it in D or OD when your on highway?
if its in D of course your rpms would be that high
Old Oct 25, 2003 | 04:10 AM
im taking the cr on a 90 mile trip tomorow ill refresh my self on the info tommorow
