94, 3.4 head torque
Old Dec 21, 2003 | 06:52 PM
zbo2's Avatar
94, 3.4 head torque
hey guys........
i have to replace the head gaskets on my sons 94 camaro convert., i'm having trouble getting the head bolt torque's, i'm pretty sure it has the stretch type bolts. i've seen a couple of differant torque settings and don't know which ones are correct, also i have been told two differant ways to do the valve lash, one was the old fashioned way of taking the slack out of the push rods and going 3/4 of a turn,with the valves in the correct position of course, and the other was torquing the valves to 18 ft lbs? it has an " S " motor......
thanks in advance........i'm sure somebody out there has the right motors manual....
Joe
Old Dec 22, 2003 | 06:39 AM
oil pan 4's Avatar
For a (all) 3.4L's, the torque specifications for the cylinder heads is:
step 1, 40 ft.lb.
step 2, 90 degree CW turn
To set the valve lash do it the old way (the 3/4 turn way). The only reference to the torquing the rocker bolts to 18 ft.lb. is for 4 cylinder camaros with 2.5L's.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
StansZ28
Feb 19, 2015 07:39 AM
