92 firebird
92 firebird
put timing chain and waterpump on 2 months ago,ran excellent.now it will start for 20 seconds and shut off,42 psi on fuel and fire great.scan tool says security problems, what could this be?
Re: 92 firebird
(I know this is an old thread and I figured its already solved)
But if its security then it would be the Vats system either the ignition cylinder or the vats module (or fuse for vats) could also be a worn key aswell.
Easy fix after checking would most likely be just bypassing the VATS system with a resistor, you need to measure the resistance value from the resistor pellet in your key, then get a resisitor to match and put it across the two VATS wires under the steering column which are two thin wires usually in a orange wire loom. (not to be confused with the yellow SRS wires).
Formula Steve
Sep 19, 2023 08:31 AM
karpetcm
Sep 29, 2015 10:08 AM
alliance12364
Sep 23, 2015 12:40 PM
