4th gen V6 top speed
Old May 7, 2003 | 12:58 PM
Black6SpdTA's Avatar
whats the top speed on a 93-97 V6 f-body?
93-97= 3.4L
98-02=3.8L
is that right for camaros and firebirds?
Old May 7, 2003 | 01:27 PM
MustangEater82's Avatar
118, they are electronically speed limited.
without it, in a 5-speed, mid 15 second car 3.4 or 3.8l car i woudl say close to 130ish maybe? My car seems to still have some steam in 4th when it hits the limiter.
Old May 7, 2003 | 01:29 PM
also forgot to point out...
93-95 are 3.4Ls, but in California in 95 you could gt a 3.8L.
96-02 are all 3.8Ls, biggest change I think is in 99 or 2000 they switch to a better flowing exhaust manifold.
Old May 7, 2003 | 02:40 PM
Wolfie's Avatar
mine will max out the 150 mph speedo it has in it
but a stock 3.8 with no limiter will go 130-somthin
Old May 8, 2003 | 01:06 PM
fbird95's Avatar
Not all cars have the speed limeter. I have been Told 5 speeds do NOt have it, not sure if its true, i Belive i do not have it, cause i have had the car going at least 120-something, not actually sure about its top speed.
Old May 8, 2003 | 01:39 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
i am sure i have had my car over 120 before also.. but the last few times i was up that fast it would cut out at like 110 ish i just think my whole electrical system is screwed up , the lights for the HVAC only come on 1/2 the time, and never used to at all (they started coming on december 21-02 at random times) and the power locks just decide when they want to work, along with the cruise control
Old May 8, 2003 | 09:43 PM
CamaroGuy22's Avatar
My previous stock 95 3.4 hit the peg on the speedometer and kept on rolling...i had the 115 speedo, if i remember correctly the peg was at what 120?
Old May 8, 2003 | 10:17 PM
The Captain's Avatar
my 99 3.8L stops gaining speed at 118, but im positive it could go faster if I got the limiter out.
Old May 8, 2003 | 10:23 PM
95 3.8's Avatar
mine stops gaining speed at 115 mph... 4500 rpm at 4th (A4)
Old May 8, 2003 | 11:13 PM
I have a 5-speed and it works 100%..
Jstu go cruising then it feels like I slam the brakes when it hits the fuel shut off.
Whats cool is if you pop the clutch in right when it hits all the guages go dead, put the car in neutral rev, and the tach, speedo, temp, oil pressure all go dead, then put the car in gear and engage the clutch and everything kicks back on magically, its awesome .
Old May 9, 2003 | 12:42 AM
fbird95's Avatar
Sorry to hear about the limiters some people have, its not like most people drive over 118 mph anyway.
canbaufo
Feb 24, 2015 10:27 AM
NewsBot
Jan 11, 2015 06:10 PM
mark0006
Dec 25, 2014 09:50 PM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
