3.4L V6 Leaking antifreeze from the back????
Old Feb 14, 2010 | 07:33 PM
Girrrrl's Avatar
Unhappy 3.4L V6 Leaking antifreeze from the back????
As quick as I pour it in is as quick as it comes out. I cannot tell exactly where it is coming from, I do know it is being funneled through the torque converter cover. I have bypassed the heater, to rule that out. The thermostat did go bad I have replaced that. I do not have white smoke in my exaust, no oil mixing. Car seems other than loosing water and getting hot, seems fine. I am thinking possible the freeze plug. How hard are they to install?
Old Feb 17, 2010 | 10:30 AM
supercharged024's Avatar
Gonna have to drop the tranny. Sucks to have to do so much work for a simple fix.
Old Feb 17, 2010 | 05:29 PM
Girrrrl's Avatar
It does suck, especially when it's like 1.50, how many are there by the trani? If you know
Old Feb 18, 2010 | 03:20 AM
95camaroinok's Avatar
Might be a good idea to get it on ramps or jack stands and see if maybe its a side freeze plug. still not much room to get in there and change it but maybe you wont have to drop the trans.
Old Feb 18, 2010 | 06:24 AM
Girrrrl's Avatar
I don't know if this make a difference or not, when the water comes out it funnels through the tor coverter cover
Old Feb 18, 2010 | 08:47 AM
Probably is a back one then, was trying to give you a little hope lol. Good luck, if you need any pointers on pullin anything we can guide you. Not too bad with the right tools.
Old Feb 20, 2010 | 02:02 AM
89 iroc zl1's Avatar
its gonna be on the back of the motor if its coming from the converter cover and youll have to drop the tranny to get to it there are three of them back there and there prolly aluminum ive had to replace 4 so far on my car
Old Feb 25, 2010 | 06:48 AM
Girrrrl's Avatar
Well i have fixed the freeze plug and got everything back together now the trans will not engage, anybody have any ideas?
Old Feb 27, 2010 | 01:16 AM
check the adjustment on the shift cable and make sure nothing is broke or unhooked
calaban
May 18, 2020 06:43 PM
warmeck
Mar 1, 2015 08:47 PM
artic94
Jan 17, 2015 11:19 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
blac94Z
Nov 28, 2014 01:53 PM
