3.4 water pump different from 2.8,3.1?
Old Jul 21, 2003 | 10:18 PM
oil pan 4's Avatar
I was looking at a cloyes timing gear set but it is only for 2.8 and 3.1's and I was thinking is it because the timing chain cover (the water pump)?
Are the blocks different?
How much have the water pumps changed?
I have a 3.4 long block covered with 2.8 stuff (intake, water pump, oil pan) will it work with the gears?
I know the cams have changed from 3.1 to 3.4 but that shouldn't matter.
Old Jul 22, 2003 | 02:37 AM
Wolfie's Avatar
the pump is the same except that v-belt pump rotate one way and serpentine belt one rotate the other
I have the cloyes true roller chain in my 3.4
Old Jul 23, 2003 | 11:22 AM
oil pan 4's Avatar
You said roller chain but you mean gears right?
Is that what you have, the so called 3.1-2.8 only timing gears in your 3.4?
Old Jul 23, 2003 | 03:19 PM
Wolfie's Avatar
thats what I have on mine, heres a pic of its sproket on the crank
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
