3.4 acts like missing under load, not much power
Old Jan 19, 2011 | 01:00 AM
joseph_zlnsk's Avatar
My 1994 seems like it has a mis under a load. Like while I'm driving. I recently bought the car. Replaced the spark plugs. Checked my coil. I checked them buy pulling the boot off the coil and seen it arching. Seems like it may just be running a little rich, has kind of a strong exhaust smell. Cat was removed by previous owner and strait pipe put in place. Replaced one of my o2 sensors so far. Just looking for ideas that would make it run like this. I've read that the cam position sensor may do this. Any ideas at all guys
Old Mar 25, 2011 | 09:32 AM
Dkbaysinger's Avatar
Re: 3.4 acts like missing under load, not much power
I had a similar situation but mine was due to putting the spark plug wires on backwards. (Wrong sides, Wrong order)
You might just double check that really quick. Its easy to check and will save you money if that is the case.
If you havent replaced anything under the hood in awhile then that shouldnt be the problem.
Not really sure.
Could you give some more details? Have you done anything to the car previous to this?
Keenan
Jan 19, 2023 12:24 PM
Bignasty85
Mar 3, 2015 04:05 PM
DetroitZ28
Feb 13, 2015 07:33 AM
XtremeLt1
Sep 13, 2002 08:50 PM
