20 months Later-3.4 EGR fixed
Old Oct 8, 2002 | 06:54 PM
  #16
CARdiac's Avatar
With the 3.4, you will get a code 70 something (3 of them) for the three solenoids in the EGR. If you are not getting the SES light, I doubt the problem is EGR related.
Old Oct 11, 2002 | 10:05 PM
  #17
blueirocz-28's Avatar
which pipe are we talking about? the upper aluminum flex pipe or the one under the egr to the manifold?
Old Oct 11, 2002 | 10:08 PM
  #18
CARdiac's Avatar
The flex tube.
Old Oct 11, 2002 | 11:28 PM
  #19
sweeeet. i know what i'm doing tomorow
Old Oct 14, 2002 | 09:03 AM
  #20
CARdiac's Avatar
Did it work?
Just FYI, the wholesale price for a new tube is less than $20
Old Oct 14, 2002 | 07:48 PM
  #21
it worked for 2 drives to town. then the light came back. can i get this tube at autozone or do i have to go to dealer? i've got a spare one from the new/used engine i had to buy, but it looks just as bad as the one on the car now before i cleaned it. btw what exactly is sea foam? i always thought it was a candy my grandma used to make..................
Old Oct 15, 2002 | 10:22 AM
  #22
CARdiac's Avatar
I think Autozone may have it.
email Dal at lockitup@bright.net He can get you the OEm part at wholesale from his dealership.
Old Oct 16, 2002 | 07:55 PM
  #23
CLEAR's Avatar
i tried to clean the ****ing pipe. i used carb cleaner and i dont even think it was clogged. i ran som wire through it and it seemed really open. i took off the vavle and cleaned to it from the pipe. i couldnt get the stupid gaskets from the dealership so i used the old ones. im still gettin the same symptoms including the *** smell and im more pissed cuz its the same or maybe worse after i spent 2 hours on it. i had the same problem on a grand am i had. i cleaned the passage to it and it worked fine for a while then the light came back on. i even bought a new egr for it but it didnt help because the pipe was clogged so i took it back. after the pipe was cleaned it worked for about 4 or 5 months and then had the same problem so im guessing that cleaning the passage will help but you will still need the valve. i guess i need to buy new gaskets and try again? i dont wanna spend $170 at advance auto parts for a new one. **** emissions.
Old Oct 16, 2002 | 09:25 PM
  #24
CARdiac's Avatar
Contact dal for the equipment, it is cheaper.
Old Oct 17, 2002 | 03:51 PM
  #25
CLEAR's Avatar
i emailed him and his reply was more expensive than me going to the dealership myself
Old Oct 21, 2002 | 11:30 AM
  #26
CARdiac's Avatar
That is unusual, he sell at wholesale. What did he quote you?
timmy39120
May 2, 2015 05:12 PM
1996LT1Z28
Apr 22, 2015 07:56 PM
edman
Mar 13, 2015 09:39 PM
squarehead
Nov 21, 2014 08:02 PM
MislMan
Jul 19, 2002 11:41 AM
