1995 camaro 3.4 V6 Will not start
Old Apr 8, 2013 | 03:56 PM
SrVile's Avatar
Unhappy 1995 camaro 3.4 V6 Will not start
Ok. The fuel pump is good. I'm getting spark. The Injectors are getting power but will not pulse. If you spray gas in the intake with a bottle it starts till you stop spraying gas. Its not vats the security light does not stay on or flash on and off. Just comes on for a sec then off and that's it. Any Ideas or further tests I can do? I know the pump is good the fuel pressure was tested.
Old Apr 10, 2013 | 01:21 PM
Z28Freak86's Avatar
Re: 1995 camaro 3.4 V6 Will not start
Check the fuse. Could be blown. Thats the only thing i can think of next to disconnect the battery for a few minutes. There should be 4 wires, power comes the fuse block, and then grounds, and the ECM sends a signal then ground. So it needs to be one or the other. If its not a fuse or constant power problem, it has to be a ECM issue.
Old Apr 10, 2013 | 01:49 PM
transamtom's Avatar
Sounds like the fuel pump,check your FP at the rail.
You should also hear the pump cycle on like a humming noise.
Old Apr 12, 2013 | 12:27 PM
SrVile's Avatar
Fuel pump is good. Holds steady 41 psi. I have had people tell me it could be a ground wire. Still looking. I have tried a different ECM still no luck. But I could try another. I can not get any one to look at this car. Seems ware I live all the mechanics do not like to work.
Old Apr 13, 2013 | 10:52 AM
transamtom's Avatar
Sorry I miss read the original post,even though your security light isn't on I still think it could be vats try doing the resistor mod and see if that works.
Old Apr 13, 2013 | 10:54 AM
transamtom's Avatar
Most would rather replace parts than try and diagnos a problem.
calaban
May 18, 2020 06:43 PM
joe777107
Dec 1, 2014 09:32 AM
Jul 4, 2005 05:00 PM
SLIMJIM
Jan 7, 2003 11:06 AM
Chrisdude
Jul 24, 2002 02:25 PM
