1994 v6 to carb
1994 v6 to carb
I recently purchased a 94 v6 camaro. I have a built 383 that i would like to put in it. What would i have to do? New k member? MEch fuel pump and sump? What about the wiring...would i have to use some custom mechanical gages? Anything else i should know? How would i hook the starter up, etc. I also have a 89 built 700r4 that i would like to retrofit. What would i have to do with this? This was all going to go into my 89 RS but i have this car and changed my mind. Any help is appreciated.
Re: 1994 v6 to carb
doing that is gonna be a TON of work. I dunno about the K-member, but i do know you have to cut a hole in the cowling to fit any kinda air cleaner. and forget puttin any kinda highrise intake on it. itll never fit and as itll be sittin you will need a cowl hood to get any type of air into the carb.
