Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
me vs a gs400 (too close for comfort)
Old Mar 2, 2004 | 02:29 PM
  #31
Steve Y's Avatar
Originally posted by Threxx
If I remember correctly the frontal area is 23 sq ft and the cD is .28
93-95 f-bodies, if I remember correctly are 22 sq ft and .34 cD
How much rwhp does a stock '99 GS400 put out?
  #32
Threxx's Avatar
Originally posted by MauriSSio
whered you get these numbers???
Lexus publishes the CD specs for the GS400 in their technical materials... as for the f-body that's just what I seem to remember from quite a bit of time on this site.
Old Mar 2, 2004 | 02:31 PM
  #33
Threxx's Avatar
If memory serves me... about 250...
Flywheel HP is about 300... some say a bit over.
The GS4's driveline, due to its 'cushy/overbuilt' design is a couple percentage points behind the industry norm for auto trannies in terms of parasitic drivetrain loss.
Old Mar 2, 2004 | 02:35 PM
  #34
Steve Y's Avatar
If that's true, then a stock LT1 6-speed should be a very close race with the GS400 from a 100 mph roll. LT1 = 262 rwhp stock but worse aero drag.
Old Mar 2, 2004 | 03:05 PM
  #35
TenaciousZ's Avatar
When and If I get a rematch with this guy i'll post the results to end this, next time I'll get a better launch and be in the correct lane I should crush him good.
Old Mar 2, 2004 | 10:57 PM
  #36
yellavette's Avatar
Steve, before you raise the bs flag, consider this. The GS400 has a drag co-efficient of .27-.29 (spoiler or not). That's better than 99% of the sports cars ever built including the c5. My Z is .33 and my vette is .32 for comparison. Considering the GS400 has 300 hp compared to the z's 275....and the fact that at 100 mph weight is not much of a factor, why's it impossible that the higher hp car with better aerodynamics is faster at high speed?
Jason
Old Mar 3, 2004 | 10:49 AM
  #37
Steve Y's Avatar
Jason
I think a C5 is .29. Stock the Z has the same or more rwhp than the GS400. The Z weighs about 400 lbs. less. The GS400 has a better c/d but more fronal area. He also said a Z with a muffler and a hypertech which should add at least 10-15 rwhp to the Z. So I think this race would be close or the Z would win from 100 mph. He said the Z would be left in the dust from 100 mph, remember. All of this is bench racing anyway, we need somebody that will step up to his challenge and see!
Old Mar 3, 2004 | 11:54 AM
  #38
yellavette's Avatar
I don't know either way....I was just throwing that out there for arguments sake On paper they look comparable....who knows on the street....but I think "left in the dust" is a little extreme. I've gone back and forth from Vettes to *** turbo 6's....and the difference in feel between them is amazing. Because the 350 is so loud and rumbly....with such a linear power band, you never get that "holy sh*t" type of accleration feel....whereas a smooth, quite, *** car (with comparable hp) feels faster even though it may not be. I had a supercharged 94 vette a couple years back that really didn't "feel" all that fast....not nearly as fast as my bpu Supra felt....but the first time at the strip she ran 12.20@122 which is the fastest (mph) pass I've ever made. Totally suprised me.
Jason
Old Mar 15, 2004 | 04:03 PM
  #39
gs400tx's Avatar
Lets see, a LT1 Fbody weighs 3300?, Bc my GS4 was 3700 with half a tank. I thought 3500 lbs was about right for an Lt1 fbody.
Frontal area is about a wash. The wider tires on the Fbody offset the lower height. Both around 22-23sq/feet.
I think a LT1 6speed is going into overdrive at about 125 .. my GS4 is still in direct 1-1 from 100 to 135. Not to mention its pretty much in a sweetspot in the 115-125 range. .. just ask the LS1 drivers that dont gain any distance on me there..
GM published a CD .36 for the 4th gen fbody when it first came out.
Old Mar 16, 2004 | 11:30 AM
  #40
Steve Y's Avatar
Re: ?
You are right about the GS400's weight, my bad. I looked it up and it said 3690 lbs. A 6-speed hardtop LT1 weighs about 3450 lbs. So the Z has a 240 lb. advantage. Stock LT1 6-speeds dyno about 257 rwhp stock. What does the GS400 dyno stock? This race is just speculation anyway until we find two guys with these cars and ball of steel to do this.
Old Mar 16, 2004 | 05:35 PM
  #41
gs400tx's Avatar
most GS4s dynojet around 240-245
based on my experience.
Mine was 240 on the MTI-DJ.
Probably ~5percent less hp at the tires than a LT1.
Its usually below 80 the Lt1 cars have an advantage. The extra weight of the GS and less torque gives the advantage to the fbody until aerodynamics come into play. At that point, weight is a minimal factor and the aero/gearing of the 5speed auto in the GS begins to show up..
Its usually within a car one way or the other (on a lt1 with exhaust) up till 100, then the GS has a minor advantage.
A good example is the time I played with a convert LT1-Vette.
The top was up on the vette, it was an auto trans. From 15mph to 115, the distance stayed about exactly the same. The vette was about .5 cars back. About the same as the 300ZX-TT I played with (several times) up to the 120 range. Id would say for LT1-fbodies, it really comes down to who punches it first to up about 100 or so.. its that close.
Old Mar 16, 2004 | 05:39 PM
  #42
FastZinTennessee's Avatar
Re: ?
Do these LS1's have two spark plug wires pulled or what?!?!
Old Mar 16, 2004 | 05:46 PM
  #43
gs400tx's Avatar
if they do they must drive like that all the time
I can probably find about 3 or 4 local peeps in the WS6s and SSs that will confirm my comments. They probably are on this board...
Dont forget, a LS1 TA with the headlights up is just about the same CD as a LT1 car. A little better on the Z.
Isnt your average LT1 fbody about 2 cars back on an LS1 in the 70-120 range.. I would expect no more distance for an LS1-gs4 matchup
According to car and driver, an auto LS1 SS takes 6.4 seconds (13.4 to 100, 19.8 to 120) to go from 100 to 120. I think the GS4 is right about 6.6 to 6.8. I cant find it now... I think the 100 time was 15.4 and the 120 time was 22.x
Pretty small differences there...
Old Mar 16, 2004 | 06:23 PM
  #44
Steve Y's Avatar
Re: most GS4s dynojet around 240-245
So what do you think about Threxx's statement? He said a stock GS400 will leave a Z28 ('94 T-top automatic, 2.73s, muffler, and hypertech) in the dust from a 100 mph roll.
Old Mar 16, 2004 | 06:45 PM
  #45
gs400tx's Avatar
his must be a little stouter than mine
My car would put ~ carlength or maybe a little more but thats probably about all..
Im a little older (but not much smarter).. and dont do quite as much "testing" as I used to.
I get most of my heavy right foot time in the camaro lately.
take care/be careful
edit 9:30
I actually have a friend that has a 93-hawk with macs and 1.6s. It made 290 at the tires. He and I have never played, He should put a car on me at least I would think. If it ever happens I will be sure and post.. either way.
