ls1 couldnt hang
I take a trip to this little place I like to race in chicago,feeling pretty confident cause i just tossed a 4.10 gear in my car and have other slight mods.(By the way Its a 99 z28 a4 65000 miles).Feeling pretty confident i aproached a 03 evo-7 by mitsubishi> now i know those cars put out close to 290 power and got awd,but this guy made me look silly first he jumped about 3 cars right out in front but i just couldnt catch this guy.we finished the 1/4 and he still had about 3 cars on me.Now this guys says he put a high flow exhaust on this evo,im skeptical cause i know ls1's with 4.10's aint no joke and i had almost no spin on the launch.Are the evos really that fast?? or is this guy pullin some sh** out of his a**.By the way i lost 50 bucks.
Evos can run low 13s stock. It is very possible for him to beat you by 3 cars, especially on the street where awd hooks much better than rear wheel drive, even if you didn't get any spin, it's obvious you weren't able to hit hte gas as hard as you would have liked off the start.
I agree, 4.10 is too much gear for you. You would be better off with 3.73s
Wait, you changed the gears but you still have factory a stall? Shame on you
Change your gears to 3.73, get a good stall (at least 3000) and some traction, then race him again and get your 50 dollars back
Actually this doesn't surprise me one bit, the Lancer Evo 8 uses a Mitsu 4G63 engine.... for anyone not familar with this engine it is the same engine in the DSMs. And with the AWD advantage, they are easily going to open up a HUGE gap on any RWD or FWD car....and that advantage is extremly pronounced on the street!
But you not being able to catch him hmmm......He must either be one HELL of a good driver, or he isn't telling you something. Stock they are rated at 271hp at the flywheel and are only putting down about 235 AWHP, but opening up the exhaust will easily add 15+ AWHP. But for him to maintain that advantage...especially with the drivetrain loss of an AWD car, he had to also be running a boost controller or maybe a re-programmed ECU(I know Vishnu now has ECUs available for the Lancer to make alot more power).
Stock Evo's are running 14.0-13.7@98-100mph....which makes me really wonder why a LS1 with minor mods...and 4.10s out back wouldn't be able to real in that evo quick.
I'm not sure what speed you got up to, but if you shut down at anything under 80 there was just no hope of you ever catching him.....Bet him another $50 but this time challenge him to a 60mph roll......I bet he will back off real quick!
93redbird Dude.. you over geared..
Originally posted by transxtreme
I totaly agree. A weird coincidence is that my buddy tim owns a 00 Ram air TA. He has 342 gears, lid , maff, and hypertech. He raced a Lancer EVO with exhaust and intake. I was in the car and we know the kid from school. We rolled up to a light and they went at it from a dead stop. The EVO popped out in the beginning but soon after tim just passed and gained more on him and smoked him by about 2 cars. Was this EVO by chance silver and have OZ wheels? LOLI dont know wats up but he must have more mods in it. Where do you race in chicago, i like to hit up the expressway when i pick my sister up from Loyola and go to china town with my buddies when i get bored, just to toy with the ricers..
I have a 92 talon turbo awd.And 99taws6 with 450 hp.
Best my ta has done on street tires so far is pathetic 13.35 at 109mph with a 2.27 60ft.I am at 2000 feet above sea level and that also hurts times.The above time is street tires.
I have a bad clutch in the talon but they usually run easy mid thirteens with a bit of boost and mild mods.
The evos already run around 17psi I think but a boost controller still helps keep it constant to redline from an article I read.
They are a bit underated like the ls1 and are lighter.And they have next to no wheelspin stock.There is no way you can't have wheelspin with your 4.10 gears..off the line and thru the gears.
If you want to play with awd cars that can get 1.8 60fts or even lower on street tires you need to run around with nitto drag radials or the new et street drag radials or run with some bfg drags or et streets.
And still agree a good combo like a 3500 stall and 3.42 or maybe 3.73 with an auto will likely work much better for you.
And if you really want to put the hurt down on a lot of this stuff get some serious mods like heads,cam,long tubes,etc or for cheap and fast get some nitrous.
Next to no chance of outrunning an awd car like these from the lights.Even if the roads are bone dry and warm.If the roads are damp and cold /wet etc forget it not a chance.I incinerate just about everything off the line including awd trucks with my talon.
It will be interesting to try some rollons against my own or buddies 500 engine hp SS this season.My talon is being modified to be around 500 engine hp.Should make for some interesting races.He has only run a best of 12.5 at 115mph up here on street tires.He bought nittos but his rear end is hurting so can't use them right now.Without them I should be able to crush him.Better 60fts and lighter car and the turbo can put out some big numbers
on boost with a much bigger than stock turbo.
My friend has an Evo with a boost of 20 psi, !CAT, turbo back pipe, tuning, bigger exhaust pipes, better intake.
Lemme tell you, he spins all 4 wheels so the traction of AWD isn't as good as you say (he launches at 3 grand so that may mean something).
Evo's are underated. His put out 250 AWHP and is putting close to 290 now. Those things are really nasty just not so on the highway. He probably runs mid 12's but he knows that he will never take an LS1 from a 20+ mph roll
I'll agree that you're over geared for factory size wheels/tires. I can bet that on a true 1/4 mile track you're probably going to hit the rev limiter, or get very close, before the traps. 3.73s would be a better choice.
On a street combo, 3.73s with ~3500 stall are killer. You would have been better with stock gears and a stall than 4.10s.
