Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
L98 T/A Vs SRT4
Old Jul 26, 2005 | 11:53 AM
  #16
ZFan88's Avatar
Re: L98 T/A Vs SRT4
Don't the 350tpi actually have more torque than the LT1 and LS1...GM rated that is...not rwhp
Old Jul 26, 2005 | 12:09 PM
  #17
JBird33's Avatar
Re: L98 T/A Vs SRT4
Depends on the year, but some of the L98s came rated with as much as 345 lb/ft I think.
Old Jul 26, 2005 | 12:20 PM
  #18
85_305's Avatar
Re: L98 T/A Vs SRT4
Yup
Indeed they Did. Heck.. the TPI 305's came w/ 320lb's of torque stock
Old Jul 26, 2005 | 12:28 PM
  #19
JBird33's Avatar
Re: L98 T/A Vs SRT4
Originally Posted by 85_305
Yup
Ya ya ya, we all know whose car is faster from the factory, despite what the torque numbers may be....
Old Jul 26, 2005 | 03:28 PM
  #20
85_305's Avatar
Re: L98 T/A Vs SRT4
^Can't deny that. Poor, poor LT1
Old Jul 26, 2005 | 05:11 PM
  #21
CamaroGuy22's Avatar
Re: L98 T/A Vs SRT4
Awesome kill Those L98's have just as much torque as an LT1 yet weigh a LOT *less*
This post was edited because I wasn't thinking correctly and said that the L98's weigh *more* than the LT1's
I don't know what you consider a LOT less but a 95 A4 LT1 Camaro weights 3,475, a 92 A4 5.0 Camaro Z28 (could'nt find the 5.7, but i am sure it would weigh more) weights 3,375. The 95 M6 LT1 Camaro weights 3,390, the manual 92 Z28 weights 3,275. I don't think that is a huge difference.
Old Jul 26, 2005 | 05:20 PM
  #22
Re: L98 T/A Vs SRT4
Good Kill to the original poster!
Old Jul 26, 2005 | 05:42 PM
  #23
JBird33's Avatar
Re: L98 T/A Vs SRT4
Old Jul 26, 2005 | 07:31 PM
  #24
85_305's Avatar
Re: L98 T/A Vs SRT4
4th gens deffinently weigh more then the specs you provided. 4th gens weigh more in the 3500+lbs area, with the newer LS1's hitting 3800+lbs sometimes. 3rd genner's usually weigh in the 3200-3400lb range.
Old Jul 26, 2005 | 08:06 PM
  #25
Re: L98 T/A Vs SRT4
What specs are you using then?
My 94 Auto Z28 Convertible weighed in at 3,820 with a 3/4 tank of gas, me in it@ 200 lbs, and 50 lbs of crap in the car. The database i used lists my car at 3565, so I think the database is right on.
Keep in mind the automatic transmission adds ~85 lbs to the weight, and another ~90 lbs due to the convertible top.
There is no way a newer LS1 would hit 3,800 lbs with no passenger. I have never heard of an LS1 weighing significanly more then an LT1, if anything they weigh slightly less.
Old Jul 26, 2005 | 09:20 PM
  #26
Nick 02 Z06's Avatar
Re: L98 T/A Vs SRT4
LS1 has an Aluminum block and should way less than an LT1 but not by much.
Old Jul 26, 2005 | 10:13 PM
  #27
85_305's Avatar
Re: L98 T/A Vs SRT4
I'm just going by what other people have told me their cars weigh Your 3,620lbs estimate sounds about right. 4th gens are bigger over-all then the 3rd gens, which is where they get their weight from. In fact, that 3800+lb LS1 is from this very board. I forgot who it was, but I am pretty positive that in race-ready form (full gas, driver included) it was closer to 3900lbs.
Old Jul 26, 2005 | 10:19 PM
  #28
Schismblade's Avatar
Thumbs down Re: L98 T/A Vs SRT4
Uhh...no..
LS2.com had someone take their LS1 F body to a truck weigh in station and have it read around 3,4XX. Full tank of gas and all, minus the driver. Unless he weighs near 500lbs, it's no where near what your "friends" have been telling you.
He even scanned and posted the sheet stating it was 3,4XX.
Camaroguy is dead on actually. Verts weighs around a hundred lbs or so more than non verts. Given that LS1s have an aluminum block, LS1s will weigh a bit less than a LT1 car. So a 3,4XX reading in an empty LS1 non vert car with a full tank of gas and a 3,5XX reading on an LT1 vert car sounds right on the money.
Old Jul 26, 2005 | 10:35 PM
  #29
85_305's Avatar
Re: L98 T/A Vs SRT4
^Thats interesting. The person that has the 3800 or 3900lb LS1 (I think it may have been turbo'd or S/C'd or something..) also took his in to have it weighed in. Can you find some other proof of 4th gens weighing that little?
Old Jul 27, 2005 | 12:41 PM
  #30
Mike 92LX's Avatar
Re: L98 T/A Vs SRT4
I have seen many dual cat speed density F bodies run 14.0s and faster stock back in the day. My own 89 ttop 350 dual cat Formula once went 14.2 at 96MPH stock(could never back it up-mostly 14.4.-14.5 at 95MPH).
L98s can run just as fast as comparable LT1s easily. With bs mods(SLP cold air,SLP prom,air foil,good wires,gutted cats) stock or close to stock LT1s could be beat on the street from a dead stop easily.
Good kill. Love L98s. Might do another one day.
