Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
Car Length measurements?
Old Sep 21, 2004 | 10:38 PM
  #16
GreenZ28in503's Avatar
Thumbs down Re: Car Length measurements?
Sigh...
So...once again...since you are worried about your steering/suspension/brakes you won't take your car to the track. Where there is a long runout for you to stop on and emergency crews standing by in case something were to go wrong.
BUT!
Originally Posted by ZeeDub
but when i take it on the freeway..... god i love the onramp... i usually bust 110 before i merge on it.
You'll do this ^^^^ on a public road...an onramp which probably has a slight curve to it (vs straight line for a drag strip) and little to no place to go if say, something's messed up on the freeway and traffic comes to a screeching halt in front of you. All this while doing 110 or so which, I assure you, is a much higher speed than your high flow MAF housing, primered stinger hood, and busted *** suspension is going to help you trap in the 1/4.
Honestly it sounds like you need to park your car and fix it. When you're done go to the track and get a timeslip, or go race some fast cars on the street. Try that instead of "dancing" on stock fox bodies and running your mouth about it on here.
[/rant off]
Old Sep 21, 2004 | 11:00 PM
  #17
jthomas's Avatar
[/rant off]
i'm predicting an auto-lock for using the term "dancing".
Old Sep 21, 2004 | 11:03 PM
  #18
ZeeDub's Avatar
ok.... here we go again... first off? your the one running your mouth... and once AGAIN this post was about car length measurements.... not why i dont take my car to the track.... if i wanted your opinion? i would ask for it...... hence the reason for a forum.. no? i asked if anyone knew how to determine the difference in 1/4 mile times using car length estimates.... not why the greenz28 dude thinks i shouldnt race my car on the street..... you a cop? if so... bite me... if not? mind your own business... the reason i wont go to the track is because with my burned out bushings and other minor issues (minus all the performance stuff i want to add before hand) i dont want to pay to race and potentially screw off my car from pushing it to the max for a 14.2 trap time... when i hit 110 on the on ramp, first off u dont know which ramp im speaking of, which is actually REALLY long, downhill, and pretty straight, and second, i never push my car to the limits to get it there... i start off rolling and i never usually hit WOT...
and also... my suspension isnt "busted ***" by the way.... whatever a "busted ***" has to do with my car, i will never know, but anyways... so yeah, my bushings are bad, and i need a new rack and pinion cuz it has a very slight drip... which some power steering stop leak should fix... but i want it to be perfect...
and also............ who ever said my hood was primer? i just said it was grey.... that hood comes from the factory in grey, and no its not primer either, its a prep coating thats not sandable like primer is... no primer needed either, just shoot the paint on it and it sticks..... very simple....
and why do people bring up the 2 smallest pieces of performance on a sig line to add to their list of wise *** remarks? i could bring up his CAI and "EGR" ( ) if i wanted to be an ***.... i never said my car was modded up the *** hole man... which is why i see it as a waste of time to take it to the track right now... im not going to pull anything with pride... so why waste my time?
Old Sep 21, 2004 | 11:46 PM
  #19
Alright, yeah, that was over the line. *kicks self*
Here's my point.
yeah but i still have a lot of things i want to do with my car before i take it to the track... the suspension isnt exactly fully functional right now, im thinking new shocks all the way around and i know i need new bushings and a new rack and pinion... so i have my work cut out for me before i take it to the track, i want everything fully functional before i run it... i want my brakes redone, all that... so it will be a while before you guys get any ET info about my camaro...
and then...
various things about going fast on the street, questions about street racing etc
I'd be a hypocrite if I preached to you about not running on the street because I run on the street too when given the chance. To me though it sounds like your car needs some repair work before it sees ANY high speed activity.
i need brakes, not dire, but i will need them if im doing 120 and need to come down to 0 in a flash....
When you have to stop, 110 is 110 regardless of whether you got there at WOT or not. Worn shocks and bad bushings don't help you stop, and public roads are usually far less forgiving in "outs" if something goes wrong.
To me it just doesn't seem intelligent to take a car that needs suspension/brake repairs before its trackworthy and run it hard on the street.
Old Sep 21, 2004 | 11:54 PM
  #20
ZeeDub's Avatar
your probably right, but whether you want to believe me or not (and i couldnt blame you if you didnt, after all you dont know me) i have driving skill above all others.... i can take the same exact car as someone else and run .2 seconds less in the 1/4 (in most cases) just because i have that skill... i love driving, i do it daily, and i do it for fun.... its a skill i have actually TRIED to develop, hence i have developed it and am proud of it... i DO understand your point, totally... but at the same time i trust myself... and the car doesnt have any safety issues as far as high speed swaying or vibrating (heavily anyways) it doesnt pull in either direction when the gas is either WOT or untouched... i feel safe.. and i dont do it ALL too often, but i do it... just trust that i have been doing it this long and i take full responsibility for anything that happens....
Old Sep 22, 2004 | 01:41 AM
  #21
PWRMAD95's Avatar
Wow
Seriously, have you hit puberty yet ?
Old Sep 22, 2004 | 04:28 AM
  #22
ZeeDub's Avatar
have you?
fact is, im not tryin to fight with this guy over some BS, so im playin it as cool as i can, me and bob cosby, as well as some nuke guy already butt heads, and i dont need another..... fact is? im going to do what i do regardless of what you or anyone else thinks, because i know i can handle it... im no kid, ive been doing this for years and its always been a priority to me.... i admit how i GOT here was stupid, i lost my license for driving around doing the things i did without a care in the world..... but cops couldnt bust me for what i did do... so whenever they saw me i got pulled over for petty BS just so they could get me for somethin, in hopes to teach me a lesson... and they did... i dont DO what i DID before... but i still have loads of fun.... why build a street car that you have no fun with? i mean its not like im burnin out all around town, but on an onramp? thats the BEST place to test your acceleration.... without going to a track of course.... better than doing that in a residential...no?
Old Sep 22, 2004 | 10:06 AM
  #23
Steve Y's Avatar
So you are the best driver in the world? That's what you are saying.
Old Sep 22, 2004 | 01:45 PM
  #24
nuke61's Avatar
ZeeDub is making friends left and right, and considering he's been on this board for all of 1 whole month... pretty damn impressive
Considering your list of things you need to fix on your car, I submit that the best place to test the acceleration is NOT on the street but at a track. That way, if anything does break, it's just you and all the other people who payed to race or watch, and not some totally innocent bystander. Since you already have "driving skills above all other", you should do signficantly better than my 14.2 in a car that had more mods than your car.
Maybe it's just me, but I wanted to know what my car did BEFORE modifications, and then AFTER modifications.
Old Sep 22, 2004 | 04:40 PM
  #25
ZeeDub's Avatar
well im not you.... and i never said i was the best driver in the world, but ive been known to take 305s against 350s of the same year with the same mods and still rip em a new *******... so i have confidence in myself with that... and i also said i DO know its stupid, but hey... thats why im me, and your you.. i can handle living life and being stupid sometimes.... ciao!
Old Sep 22, 2004 | 08:03 PM
  #26
Steve Y's Avatar
You said you have driving skills above ALL others. Remember? Look back up the page. That means ALL people in the world to me. So you are the best driver in the world, that is what that means. You are full of sh*t!!!!!!!!!!!!!!!!!
Old Sep 22, 2004 | 08:05 PM
  #27
ZeeDub's Avatar
and your a flamer.... who cares?
above all others...... as in above all others that i know of... obviously im not a better driver than a stunt driver... or a top fuel drag driver... or anyone who does it professionally... but seriously? i have more skill behind the wheel than anyone i know of... and i probably got more skill than you....... got any war stories to tell about? i do.... take me all day to tell you half of em....
Old Sep 22, 2004 | 11:09 PM
  #28
stereomandan's Avatar
Seriously, take it to the track and find out. You think your car is a factory freak, but I doubt it. A LT1 feels awefully dang quick stock, because there are not a LOT of cars that are faster, stock, on the street.
Yes, 1/10 sec = 1 car length at the speeds that you typically see at the 1/4 mile dragstrip.
Dan
Old Sep 22, 2004 | 11:11 PM
  #29
ZeeDub's Avatar
i would like to, but i see no point yet... it was a simple Q, its not like i will die if i dont find out my 1/4 lol i just wanted to see how many 10ths i was ahead/behind in a street race... thats all
Old Sep 22, 2004 | 11:37 PM
  #30
Mindgame's Avatar
Red face Re: Car Length measurements?
Girls girls...
You know that old saying that goes something like..... "Be careful arguing with fools, onlookers may not be able to tell the difference"?
Some of you just need to learn how to "ignore" the pests.
Now, can we get this one back to car stuff or do we need to close it?
-Mindgame
