2002 Z28 Vs 99 Formula
My mods are below, the formula is my buddy Dave, he has a Lid, a Mass Airflow sensor, and a throttle body. Also he has some Kumo Drag radials. So we took off from the line and he spun little if at all, as did I spin little but I did spin for a moment, and he pulled on me instantly, then kept his lead of a carlength for the duration of the race (85-90mph)... Now I'm wondering why he's getting such a good lead when I have many more power-mods? Is it his jump from the tires?
A z06 intake manifold will fix that problem overnight. In fact, you might put 1/2 a car or so on HIM. They feed off of mods like headers and work together. Try cleaning your air filter too, that can be a real killer... lol
You should have pulled up to him or pulled close . he would definitly get a jump with drag radials . Actually , from the momentum he built off then line , that may have been enough for him to beat you . but I would bet your car is faster . Pull up too him from a roll and see if you dont walk him some . You should walk him some w/headers .
well the way i see it he has the same mods except headers, better gears and tires to back them up.
i can see why it was an even race.
3.73's and drag radials will cure that dilema quick. or try out some suspension stuff first. LCA's and relocation brackets will make a big difference.
