03 SRT vs. Turbo Lt1 Trans Am
Re: 03 SRT vs. Turbo Lt1 Trans Am
Originally Posted by nuke61
I've read articles about GMs Ecotec 4 banger putting out 1000+ horses, so why not a Neon motor?
Originally Posted by Z28COnrad
Like is said...the engine in that car is REBUILT after every single run.
The fact that the factory crank can "support 1000hp" is completely irrelevent, the rods will fail LONG before the stresses
the inertial forces can be minimized. Now on to the head....while the actual head itself may well be a factory neon head I promise it has been ported and given new valves
(read: NOT FACTORY STOCK), and as for the block, its probably sleaved (read: NOT FACTORY STOCK), I feel like beating some common sense into your head with the "rock I came from".
By the way, judging the car you drive, you won't be "beating me" any time soon.
BTW, your little link doesn't say one single word about stock anything nor does it say anything about 1000hp....try again chief
This little pissing contest was started when someone made the claim:
Yes, but he's running close to stage 2 times if he's running 13.2 [and later] There are very inexpensive mods for forced induction cars that make big gains. The problem is that they also reduce longevity significantly.
So what's the point? Jim took exception to that claim, based on first hand knowledge. Nobody was talking about longevity in 1000Hp motors. It was relative to whether a stage 2 motor would reduce longevity significantly. Stage 2 is only 280 hp http://www.mopar.com/srt_stage_2.htm so THAT's why Jim said it makes no difference.
Yes, it's a fact that more horsepower causes increased wear, however, it is NOT a fact that stage 2 levels cause any increased wear. It is only your *****umption that it does. Meanwhile, Jim has first hand knowledge that it doesn't. Not at street levels.
Originally Posted by Big Red Jim
It's not irrelevant at all. My statement is 100% fact.
BTW, I never said anything about beating you, as in a drag race, what I wrote was that I'd like to beat some common sense into your head (as in physically beat). Besides, I'll race your neon (which you're obviously so proud of) anyday and hand your *** directly to you. Sure you could beat me on your crotch rocket or in your 11 second mustang, but I'm calling you out in the car we are having a discussion about.
Anyway, you are correct, I assumed you meant factory stock. So in that regard I stand by my original statement, there are no factory stock 1000hp neon motors and I defy you to prove otherwise (or prove anything at all, as of right now you haven't proven anything, and its still your word against mine).
while may know a lot about drag racing you obviously have a pretty loose grasp on the english language....do you even know what "irrelevent" means? I'll clue you in, it means "of no consequence", fact or not, its IRRELEVENT.
that engine is also an inline engine; again another obvious point. inline engines are SIGNIFICANTLY stronger by design than a vee style engine. its common sense because the crank is only taking forces from one direction at any given time. it doesnt have multiple rods pushing n multiple directions.
so you tell me WHY that engine cant withstand 1000hp. and dont just say "because 1000hp has more wear than 250hp" because you will lose all creditibility.
OK...I'll break it down real simple like for you....
we were arguing about the engines ability to withstand the 1000hp not to make it.....and no just keeping the detonation in check is not all you need to worry about as I shall elaborate on shortly....
Keep in mind at ALL times that I am refuting a claim* that an SRT4 motor will make 1000hp "factory stock" (* a claim later to be clarified as "factory modified")
The head: A factory stock head that flows well enough to make useable torque at 200hp levels WILL NOT flow enough air to make 1000hp. Before you even start to think about saying "yeah well just crank up the boost" I'll tell you that this method will only work up to a point and then the flow will become far to turbulent to be usefull. The head must be ported/polished, given new valves possibly, etc. etc. etc....hence, it will cease to be factory stock
Crank: The problem with a factory crank withstanding 1000hp is not the amount of shear force due to the rods, as I already stated the rods will fail LONG before they shear the crank apart. It is the inertial force that will be experienced when the engine rapidly accelerates through the rpm band which will destroy the crank. A factory crank will not be well balanced enough to withstand this force, hence it will need to be balanced/knife edged etc. etc....and NO LONGER WILL IT BE FACTORY STOCK.....
Block: I will take back my statement that the block will not withstand 1000hp...Big Red Jim has enlightened me to the superior block design and in light of this I concede that the block MIGHT be able to withstand 1000hp if the cylinder walls are thick enough not to necessitate being sleaved.
Side note: you are missinformed about inline engines being stronger by design.
What you might be attempting to regurgitate here is that inline engines are able to rev higher than V configuration engines. This is due to the harmonics that develop at higher engine speeds in a V configuration engine which do not develop in a (properly balanced) inline engine. also....The crank is under the same number of forces in both configuration engines. It "feels" the force of the rods pushing down on it and the force of the main caps pushing up on it......the only difference is that in an inline engine these two forces act verticley and in a V engine they act at an angle......
ok where to start? head flow is whats nice about DOHC motors. the flow a TON. it could very easily flow enough for 1000hp. the head can flow that much and still make useable torque at the 200hp level from the size of the turbo. this isnt a stock ls1 we are talking about here.
let me ask you then, why there isnt an aftermarket crank for the honda B series engines? or aftermarket head? its because in stock form these parts suffice for even the 6 and 7 second drag cars. hell the first aftermarket transmission just came out not too long ago for them. the stock head on a honda can see over 800whp from what ive seen.
i still have not seen any proof yet. just reiteration.
The definition of the word stock over the years has been giving many different meanings, usually twisted to accomadate your own point. "stock" most times means its factory POS. like an LT1 head, but when we talk about a factory modifed part. like an LT4 head. yes its still considered stock but by no means a pos. and no one wants to draw the line there. if GM had AFR make stage 3 ported heads for fbodys. the heads would be considered stock since they came straight from the factory even though they can flow enough for over 600hp. and it would be used as a bragging tool in an argument. kinda like how "stock" supra motors can handle 800hp. its sure can the factory built it with stout components. components similar to what you would buy from the aftermarket. however when toyota used it, its "stock" when you build it with the same parts. its not. peopel need to draw the line between stock and cheap part. in this case the srt-4 head is stock, it hasnt been replaced so its stock.
What does rapidly mean? RPMs are RPMS no matter how much power you make. 1000hp at 5k rpms is no different than 500hp at 5k rpms. what changes is TENSILE load because more pressure is being put down on the pistons which put more loads on the rods. NOT the crank. RPMS hurts cranks, not Tensile load. and whats that about not being well balanced enough? if your never change the weight of the pistons or rods, then the motor will always be balanced, balancing has ZERO to do with power. balancing is to control harmonic resonances, as they can create vibrations that can wear bearings, shatter the oil pump etc, until you change the rods and pistons, you will not have any additional harmonic resonance just be cause you added hp.
Originally Posted by 87camracer
do you have a factual basis for any of what you just said? you still didnt prove anything, you just reiterated what you have already said.....i still have not seen any proof yet. just reiteration.
When did this discussion become about honda B series engines? This whole little paragraph you just typed is completely irrelevent. Now before you say "its not irrelevent, its %100 fact", please see above post for definition of the word irrelevent.
...what changes is TENSILE load....
again, wrong....the LOAD (not pressure) is put from the piston onto the wrist pin, wrist pin onto rod, rod onto rod bearing, and rod bearing onto crank, crank onto crank bearing and finally crank bearing onto main cap. Then if you want to keep going from the main cap the load is transferred into the bolts holding the main cap on, then from the bolts to the block , then from the block to the motor mounts......etc. etc. etc.. This is all an example of aplication of newtons third law of motion .....point being the loading does not stop at the rods, or do you think you can argue with Sir Isaac Newton?
... just be cause you added horsepower
This will be my last post in this thread, I dont even care anymore, if you want to go on living believing that a stock neon motor will make 1000hp then go ahead....
Originally Posted by stereomandan
You have a weird definition of stock. So now stock SRT4's are going 13.2-13.2
Stock is stock, as in how it was drove off the factory floor. A bov and cranked boost is not anywhere near stock.
Dan
Stock is stock, as in how it was drove off the factory floor. A bov and cranked boost is not anywhere near stock.Dan
In this context rapidly means accelerating through the RPM band more quickly. Say a stock motor will go from 1000 rpm to 5000 rpm in 4 seconds, a heavily modified motor will accelerate from 1k to 5k in maybe 2 seconds (given the same gearing etc.). I was talking about a 1000hp motor accelerating through its rpm range more quickly than stock which causes INCREASED INERTIAL LOADS ...you do know what inertia is dont you?
My goodness, please tell me you did not just try to tell me that going to redline faster due to more hp means that the crank is turning higher Rpms than the redline. you will ALWAYS get to peak power faster with more power. your rpms NEVER under no circumstance change. it doesnt matter how fast you get to peak/redline . what you are trying to say is transient torque is affected,transient torque is a measure of how quickly an engine can accelerate (including under load) through its useful rpm range. Stated another way, under sudden conditions of WOT, how fast it will span from low to high rpm. From a measurement standpoint. again transient tq does NOT cause problems, after all cranks were designed to spin. RPMS too many RPMS with a poor rod to stroke ratio is what causes problems.
here you are just plain wrong, tensile loads are axial loads which pull away from a member, or stretch it. Notice, if you will, the striking similarity between the word "tensile" and the word "tension", see there, its not so hard. The loads we are discussing are compressive (and in the case of the crank, shear).
Wrongs again, you just gave the OPPOSITE meaning of what Tensile is, Tensile is a Compression load, its does not stretch. it compresses!! here is an axial load tester http://www.p-h-s.co.uk/Auto_L5.htm it puts tension on both ends of the tool to compress it inwards. to see its limits before bending form
Load is a product of cylinder pressure, pressure which creates the twisting force we all love and call tourqe, there is absolutly NO dfference between pressure and load, not from a mechanical stand point and not from a technical standpoint. everything you just said in that comment was you explaining partially how Tq makes the car move.....
"because" is one word pal.
I made a mistake, I didnt know we were graded on this, feel free to point out all my spelling errors
$10 says that you come on here and post again.
I have no need or desire to "prove" anything to you, or anyone else for that matter. Proof of what I type can be found in Engineering Mechanics text books ( Statics, Fluid Dynamics, Mechanics of Materials) If you don't believe me then go look it up there. Either way I really dont care.
I guess you're right. I absolutely love arguing about stuff like this. I'll give you your $10 as soon as you come to my house and pick it up
Now I was assuming that you knew what inertia, tension, and compression are and I guess I was wrong....lets consult a dictionary shall we....
Inertia: a property of matter by which it remains at rest or in uniform motion in the same straight line unless acted upon by some external force.
Applied to the crank: If the crank accelerates too quickly the inertial forces may cause it to flex and break. Notice the use of the word "accelerate". This has nothing to do with redline, or even any specific rpm. If the crank accelerated from 1000rpm to 1001rpm in .00000000000000001 seconds (or tried to) the inertial force would tear the crank apart like a piece of paper. This is what I am talking about with respect to the neon crank.
http://www.m-w.com/cgi-bin/dictionar...ary&va=tension
http://www.m-w.com/cgi-bin/dictionar...ary&va=tensile
...see above and read em and weep. Tension is THE OPPOSITE OF COMPRESSION. THERE ARE NO TENSILE FORCES ACTING ON A ROD IN AN ENGINE. That instrument tests axial loads which can be TENSION OR COMPRESSION. For compression it will push the member against itself for tension it will pull it apart. I have first hand experience using such a machine to test a piece of aluminum.
Now....difference between pressure and load.. Pressure is Load per unit area. Load is a force. Pressure is measured in PSI, Bar, Kpa, etc. etc.
Load is measured in Lbs. and newtons. How bout some water to wash all that down now that you have to eat your words.
Honestly, my room mate and I were on the ground laughing when we read "
tensile is a Compression load, its does not stretch. it compresses!! ".....seriously man, keep it coming, this is truly entertaining.
. Now I was assuming that you knew what inertia, tension, and compression are and I guess I was wrong....lets consult a dictionary shall we....
you still have yet to prove anything to me except that you have an unfounded hypothesis that has no factual basis for this discussion. .
oh man you too, this is too much.....ok lets get this straight...I say : "I dont need or want to prove this to you, if you want proof look it up"
You say: "well you still haven't proved it"
.....ooook.....we have covered this...I am not going to sit here online and explain engineering mechanics to you, If you want to learn, look it up. For the crank discussion look in books title "statics", "dynamics", and "mechanics of materials" and if you're really into it "elasticity theory"....for the cylinder head look in "fluid dynamics".
