Will i need anything else for my brakes?
Old Sep 30, 2004 | 10:19 PM
Sanger's Avatar
Time for some new pads for the Z28, so I'm going with the Hawk HPS pads since I'm not a auto-crosser and just do street and ocassional drag strip driving. Will I need anything else for my brake job, or just swapping in the new pads be fine? My rotors look like they are in fairly good shape as well. Thanks in advance!
Old Sep 30, 2004 | 11:02 PM
Z95m6's Avatar
Re: Will i need anything else for my brakes?
instead of wasting money on high dollar pads just get an LS1 set up. I got mine for $165 shipped and it out brakes aftermarket pads 10x's over. I reused the stock rotors and pads that came with the setup and they are still superior to my buddies stock LT1 with aftermarket pads.
Old Oct 1, 2004 | 12:07 AM
Sanger's Avatar
Where can I get an entire LS1 setup new? Will it come with the pads too?
Old Oct 1, 2004 | 12:22 AM
Z95m6's Avatar
you can't get it new but you can get "kits" off of wrecked cars on Ebay. The kits are super cheap and if you get a complete one it will come with pads and rotors.
Old Oct 1, 2004 | 11:36 AM
Sanger's Avatar
Should I look for a set that contains the caliper assembly and rotors? Will the calipers alone work with my 97 discs?
Old Oct 1, 2004 | 12:20 PM
Z95m6's Avatar
You need to find a kit that has, calipers, rotors, brake lines, and the spindles. You can make the LT1 brake lines fit. The LT1 rotors won't work as the LS1 set up uses 12in rotors while the LT1 rotors are only 11in.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
