Why an adjustable panhard rod???
Old Jan 20, 2005 | 02:01 PM
LPE_wannabe's Avatar
Arrow Why an adjustable panhard rod???
the title kind of explains this thread...why do you need an adjustable panhard rod??? thanks
Old Jan 20, 2005 | 02:48 PM
unvc92camarors's Avatar
Re: Why an adjustable panhard rod???
re-centers the rear after you lower the car
the rear will be ~1/2" or whatever to one side
this will make it go back to stock looking (good if you don't want to rub your tires on the wheel well and makes it look better)
Old Jan 20, 2005 | 03:09 PM
so i'm guessing i need an adjustable one or does the non-adj. move it over??? who do i get to line up the panhard rod and the torque arm after it's installed??? thanks again
Old Jan 20, 2005 | 03:50 PM
97FormulaWS-6's Avatar
TA - you pretty much setup yourself.. -2* pinion angle is pretty standard for street cars
The PHR gets adjusted on any alignment rack when you have the car aligned. In certian circumstances I've adjusted PHRs with no rack, and just adjust and check/meaure method, mainly for re-centering for large tires in the back.
Devinfoote87
Feb 12, 2016 03:21 PM
realistyc
Jul 28, 2015 07:32 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
mrwz28
Jul 8, 2015 09:11 PM
