Who SFC Weld-On San Jose
Old May 10, 2016 | 07:43 PM
CafeRob's Avatar
Does anyone know a place I can get my SFC's welded on for a decent price, and by someone that knows what they are doing?
I got a quote for over $500 if they pull the carpet and $400 if I pull the carpet.
Seems kind of high for welding on SFC's?!?
Old May 10, 2016 | 11:10 PM
Fatdog2's Avatar
Re: Who SFC Weld-On San Jose
I've been a member here since the late 90's(off and On again) and I've never heard of the carpets being removed to install sub frame connectors.I would go to a place that installs exhaust parts because they have welding equipment.One member years ago had the sfc's welded and bolted but that may be overkill.I could be wrong,as I've been wrong 3 times this year and the year is still young.Hope this helps.(Midas)?Hope this helps.
Old May 11, 2016 | 08:32 AM
They just pull the carpet up at the edges to prevent the heat from burning/melting the backing. You also have to protect the fuel lines on the driver side.
Old May 11, 2016 | 12:28 PM
CafeRob's Avatar
No exhaust place will touch it around here, unless a SJ local knows one. I can pull the carpet myself but they still want a pretty penny. Ill call midas.
Anyone near San Jose that someone knows?
Old Jun 3, 2016 | 08:36 AM
JakeRobb's Avatar
Super Moderator
So, what happened?
I'd suggest an independent exhaust shop, not a national chain like Midas. Better yet, find a general-purpose machine/fabrication shop.
Old Jun 3, 2016 | 03:00 PM
CafeRob's Avatar
So, what happened?
I got a hold of a local guy in Santa Clara that said if I prep the SBC's and the weld points, he can do it for around 300. No need to pull the carpet but If I did for the day then it might be good.
My passenger seat is already out, rear seats out, headliner out, carpet needs to be replaced but I can't do both at the same time so Ill most likely peel it back.
x20dragon
Aug 8, 2018 05:27 PM
NewsBot
Apr 19, 2016 08:40 AM
germ79
Apr 13, 2016 07:30 PM
Stephen68
Exhaust System
Mar 23, 2016 10:28 PM
marlar98
Mar 18, 2016 11:08 AM
