Who makes 90/10's and 70/30's for 4th gens?
Old Mar 2, 2005 | 10:31 PM
30thCamaroZ's Avatar
I need to know who makes 90/10's for the front and 70/30's for the back for 4th gens. Direct linkis would be great but anything will help. Thanks, Jarred
Old Mar 3, 2005 | 02:12 PM
My Red 93Z-28's Avatar
Re: Who makes 90/10's and 70/30's for 4th gens?
I think I remember reading that HAL adj. for the front are 90/10. Check Thunder Racing. Not sure about the back though.
Old Mar 3, 2005 | 02:24 PM
DarkHorse's Avatar
You're going to get the typical response on this one. 90% of the people on this board have tons of money so they only recommend $1000 worth of shocks/struts. All you'll hear is HAL/QA1
Koni makes them too. They're also a bit pricey. I bought Comp Engineering rears for mine and i'll probably go with stock replacement fronts as I have no need for all out drag shocks when I've already reached my cars goal.
Keep an eye on used parts as well.
Old Mar 3, 2005 | 02:39 PM
whatsup's Avatar
Just racing?? Maybe look at airbag suspension on rear and junk shocks on the front ( drill a small hole to get the oil out ).
Old Mar 3, 2005 | 09:23 PM
z71camaro's Avatar
V6 Springs and struts with a hole in the strut.
Old Mar 4, 2005 | 11:47 AM
mongse_1's Avatar
Well, I'll throw in my typical response. The HAL R's are a 90/10 shock. You have 3 choices for spring rates too, 275/300/315. AFCO's double-adj. fronts are a step up, plus AFCO has a ton of spring rates in their AFCOil line.
For the rears, just about anything will work. I'm running AFCOs up front and will probably throw some single-adj QA1s in the back w/ stock springs.
Old Mar 6, 2005 | 11:04 PM
a walker's Avatar
$1000? The complete package for front and rear is only $700, and that's with the "R" series struts. The Konis are even more expensive, and don't come with springs.
Old Mar 7, 2005 | 03:37 PM
NOSCaMaRo's Avatar
I am for QA1 too...yes a bit pricey but actaully affordable compared to others and considering the quality.
I got a complete kit for $689, it is a little more to go with the front drags
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
JasonD
Jul 15, 2002 02:17 PM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
CamaroRSguy
12
Jul 8, 2002 09:39 PM
