where can I get come C5 brackets from?
Nobody seems to have any anymore and I've been looking for a set to pick up in the next month or so. Picked up some C5 front caliper assemblies for a song so I want to make some use of them. I read that there is someone who's supposed to be making them cheaper but can't find anything, maybe I'm not using the right search terms...
can anybody help point me in the right direction?
Re: where can I get come C5 brackets from?
www.frrax.com/rrforum Go to the Classified section under Bob Bishop C5 brackets. $279 and may be the last batch he makes. Otherwise LG motorsports makes some brackets to upgrade to 13" rotor using the stock LS1 brake calipers.
I dont think I'd want to use the LG stuff. I'll get my hands on some of the correct brackets for the swap. Want to use all C5 stuff...especially since I have the calipers!
I believe with the LG brackets, you only need to modify a little lip on the C5 calipers to use those if I remember correctly. OTOH, I would rather have a set of Bob Bishop's brackets as well, he is the only one who made them. They are doing one last production run of these and they only need a few more people to complete the order. You can go here: http://frrax.com/rrforum/index.php?a...6&t=2615&st=45 after registering on the site and post your order for a set of brackets if you want in on it. This should be the last production run of the only TRUE C5 conversion bracket on the market.
Nayr
03-03-2023 08:34 PM
