When changing your brake pads...
Old May 7, 2004 | 11:26 PM
Slappy3243's Avatar
Do you put any sort of grease on the back of them? Some people swear by it and say it prevents the sqeeks. I just make sure that the brake pistons are really clean so they make good contact with the pads. Should I also be using ant-sqeek grease?
Old May 8, 2004 | 12:51 AM
1 Nasty Bird's Avatar
get a bottle of the red CRC brake quite crap, trust me its worth the 5-6 bux!
Old May 8, 2004 | 10:08 AM
Slappy3243's Avatar
Thanks, I just picked some up. I guess it won't hurt to use it.
Old May 8, 2004 | 06:27 PM
Rashiki's Avatar
i usually use some of the grease on the part where the pad comes in to contact with the caliper so it slides nicely.
Old May 9, 2004 | 10:31 AM
Hyperspeed97z28's Avatar
I always clean my caliper guide pins and re apply anti seize each time they are removed, and also I spray the back of the brake pads with that red brake quiet stuff, it defiently works !!!
Old May 9, 2004 | 09:11 PM
#7's Avatar
Yeah the greasing the guide pins are my #1 thing when swappin pads. If they seize, warps rotors and lessens braking power.
Old May 9, 2004 | 09:41 PM
JoeliusZ28's Avatar
Ive got a slight squeak on my passenger side rear brake... however Ive changed the brake pads since I bought the car but it squeaked even before then. Could this fix that squeak for me? I had never heard of this before.
Old May 12, 2004 | 03:32 AM
pvkn1ght's Avatar
I recently did the rear pads + machined rotor but did not grease the rear slidepins. To do so looked like it would require removing (not just swiveling) the caliper from the caliper bracket and that lower caliper bolt is REALLY hard to get to
When you say slidepins, these are "bolts" with the rubber "expanding" covers on them, right? Can these be greased w/o unbolting the entire caliper?
Now I'm paranod of seizing!
Thanks, Brian
dluna333
15
Mar 13, 2015 12:30 PM
captcorvette
Mar 7, 2015 12:37 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Jul 4, 2005 05:00 PM
