Wheel hop in reverse
Old Aug 21, 2005 | 10:09 PM
OBE1 95Z28's Avatar
Rear suspension: Spohn first generation adjustable torque arm (slider style), tubular LCAs, lower control arm relocation brackets, Moser 9", Eibach sport springs, tubular PHR, Bilstein shocks.
Issue: I get moderate to severe wheel hop, only in reverse, with mild to medium acceleration. I've tried setting my pinion angle to 0 degrees (normally I have it a negative 2 degrees), I've tried the middle hole on the LCA relocation brackets (normally I have them in the lower hole) and no change in the wheel hop. Forward is great (no wheel hop). Suggestions?
Old Aug 21, 2005 | 11:56 PM
Re: Wheel hop in reverse
Originally Posted by OBE1 95Z28
... Suggestions?
Yeah, quit doing that in reverse, doh! It isn't made for that. Stuff will break if you keep it up. I can almost guarantee it.
Old Aug 22, 2005 | 09:31 AM
OBE1 95Z28's Avatar
Shoebox, this is under mild to medium acceleration.
Old Aug 22, 2005 | 12:01 PM
wbna0149's Avatar
Ditto what shoebox said.
Old Aug 22, 2005 | 12:21 PM
WS6store.com's Avatar
The suspension modifications you purchased are designed to help reduce wheelhop in the forward direction, it's not designed to reduce it going in reverse
Old Aug 22, 2005 | 12:30 PM
OBE1 95Z28's Avatar
I'm not sure you guys are grasping the fact that this is with me easing it in reverse. Never had this issue with the stock setup.
Old Aug 22, 2005 | 12:50 PM
Joe 1320's Avatar
I experienced the same thing. When I went with LCA relocation brackets, my foreward traction increased but the car exhibited increased wheel hop in reverse. Evidently what is added to foreward momentum is subtracted in reverse. Remove the relocation brackets or quit stabbing the throttle in reverse.
Old Aug 24, 2005 | 02:22 PM
RE AND CHERYL's Avatar
What the hell do you need mild to moderate acceleration in reverse? I've eased into it in reverse a hundred times and never spun the tires. However, if I do spin the tires in reverse I get severe wheel hop every time. If your worried about traction in reverse, go for it. I'd rather work on having traction going forward.
Old Aug 24, 2005 | 10:04 PM
ssPetess's Avatar
My reverse wheel hop went away with my new TA. I also replaced the TA mount and tranny mount. No more wheel hop in reverse. I also have all other suspension mods including relocation brackets.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Beave2780
Jul 7, 2015 06:36 AM
SAR2K
Sep 1, 2002 10:49 AM
wytblur
Aug 5, 2002 02:03 PM
