wheel hop and body twist\sway
Old Jul 13, 2009 | 02:57 PM
JC95Z's Avatar
ok so im getting alot of wheel hop on hard take offs but my main problem is when i punch it from any speed or even just excellerate the car pulls to the left and the rear feels like somethings loose. Possible trailing arm bushings? any ideas?
Old Jul 14, 2009 | 05:21 AM
Worn rear lower control arm bushings would produce those symptoms. The LCA's are the only thing holding the rear axle perpendicular to the longitudinal axis of the vehicle. If the "pull left" under acceleration also causes the rear of the body to shift significanty to one side, look at the panhard rod/bushings.
Old Jul 14, 2009 | 10:28 AM
JC95Z's Avatar
Thank you....I will replace these today and see if this helps...kinda what i suspected but wanted a secound apinion.Also suck on "proper Terms" of parts.lol thanks again for the help
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
8T8IROC
Mar 26, 2015 09:02 PM
CARiD
Feb 9, 2015 09:35 AM
