Whats up with my brakes?
Old 03-03-2005, 02:11 PM
95z2814's Avatar
When I am almost to a complete stop at about 5mph it my low traction light comes on and it almost feels like my brakes lose power for about 2 seconds? Any Ideas?
Craig
95z2814 is offline
Old 03-03-2005, 04:02 PM
Super Moderator
Brent94Z's Avatar
Re: Whats up with my brakes?
Dealership will likely tell you that you need a new sensor. However, I've seen that many times it is just a bad connection. My Trans Am did the SAME thing and it was rather dangerous! All I did was unplug each electrical connector (front wheels, rear differential, ABS module under the hood) and then slightly bend the prongs over... just a little... and then plug it back in. After I did this the car never had another problem with the LOW TRAC light coming no and me almost running through the intersection or into the back of somebody!
This will take a little time because you have to jack it up to remove the front wheels/tires and to get to the rear, but it's a heck of a lot cheaper than a new sensor!
If you have a buddy who can scan it for you with one of the scanners that can read brake codes, you can narrow it down to where the problem is and then you won't have as much jacking to do.
Also, this is the LT1 Engine tech forum. I'll move this to the brakes forum
Brent94Z is offline
Old 03-03-2005, 09:28 PM
OBE1 95Z28's Avatar
I had this issue when my 95 Z28 was under warranty; the dealership said they remove the rear ABS sensor (mounted in the top of the differential) and cleaned the sensor.
OBE1 95Z28 is offline
magman
04-15-2016 03:08 AM
IndyZman
10-22-2015 02:17 PM
Matt Dreessen
09-09-2015 09:58 PM
cohopefull
09-08-2015 03:22 PM
maverickmk
09-01-2015 09:17 PM
Quick Reply: Whats up with my brakes?
