What size are the ABS brake line nuts?
Old Oct 23, 2007 | 09:38 PM
B-Rad420's Avatar
I need to remove the ABS brake lines so I can pull the engine out the bottom but I dont know if I need to buy SAE or METRIC wrenches to do it...or should I just use the ole' vice grips?
Old Oct 24, 2007 | 05:48 AM
RE AND CHERYL's Avatar
12mm I believe. I had to gently use vise grips on mine because they were so tight.
Re'
Old Oct 24, 2007 | 10:51 PM
B-Rad420's Avatar
If I just get stainless braided brake lines will this solve my problem? I havent looked at how the attach yet and which ones need to be removed.
Old Oct 25, 2007 | 10:42 AM
wrd1972's Avatar
Yes 12 mm.
They can be insanely tight, and it is easy to round them over then you are screwed.
I took a crows foot wrench and heated it up then closed it some to make it closer to 11.8mm or so. This makes it fit the flare nut very tight with no slop, in fact I have to force it on slightly. Doing this will help ensure you dont round it over.
The vice grips can work but you are at risk of still damaging the flare nut. Try what i suggested above and the flare nut will not get damaged.
Old Oct 25, 2007 | 03:58 PM
B-Rad420's Avatar
After looking up pics of each wrench it seems like the flare nut wrench would work best since it has more than 2 sides. It seems like I could just use a regular open ended wrench instead of the crows foot.
Old Oct 25, 2007 | 05:10 PM
Compstall's Avatar
Bingo! Brake line nuts are soft and easily round off. You have the best chance of winning this battle using the right tool for the job.
Old Oct 25, 2007 | 08:23 PM
wrd1972's Avatar
Yup, Thats why I forced my tool to fit snug and my flare nuts show no sign of wear at all. It is insane how tight those thing can get.
HectorM52
Jul 30, 2017 11:46 AM
zxtce
Mar 12, 2015 08:06 PM
Jazsun
Dec 29, 2014 12:14 PM
kclarson
Aug 22, 2002 04:04 PM
