What rotors to buy for C5 upgrade?
Old May 25, 2004 | 05:19 PM
W3dgy's Avatar
I just ordered the adapter brackets from LG, Now i just want to know what rotors i should get. im trying to keep cost down, and i dont want any cross driled.
I think i have gotten it down to 3
1. power slots
2. frozen brembo blanks
3. kvr slots
what do you guys think, is it worth it the have the frozen brembos, but on the other hand i like the finish on the kvr and powerslots. i have also read that powerslot buys their blanks from brembo. is that true? they are all about the same price (around $230 shipped) any other brands i missed? remember im looking for C5 spec rotors. and they will be used for street, and very very little track.
Old May 25, 2004 | 11:25 PM
Xride's Avatar
I think your list is almost in order of costs, and all good.
2, 3, 1
is most to least (I think)
and you cant go wonge with any.
I personally pick the frozen brembo;s
Old May 26, 2004 | 03:06 AM
Lucas Black's Avatar
well, if you're car is mainly just a street car, why not just get c5 stock rotors?
go to autozone and pick up c5 replacement rotors....
for a street car, i don't see the need to buy those more expensive rotors....it's not really like you're using them to any sort of extreme....
and if you still feel like spending more money, get stainless steel brake lines and use a better brake fluid...
Old May 26, 2004 | 11:44 AM
Chris 96 WS6's Avatar
Even on the track none of those above are any better really than stock C5 rotors properly broken in.
All the drilling and slotting and cryo-ing is just flushing money down the toilet. Stock rotors are cheap enough you could replace them several times for the same cost as the above options.
Old May 26, 2004 | 11:46 AM
W3dgy's Avatar
that realy sounds like a good idea lucas. i just checked autozone and they are $50 each. if i did that i could buy some braded lines. i know that the aimco rotors for the f-body are much better then stock, so i would guess that aimco vette rotors are pretty good aswell. It would look kinda dumb with some powerslots in front and rusty stockers in the back anyway.
when i change the lines, should i change the fluid as well? what kind of fluid should i get?
Old May 26, 2004 | 01:28 PM
i'm assuming that would be possibly one of the most convenient times to change the brake fluid.
again, with the fact that your car is mainly just a street car, you're not going to need some real high performance brake fluid that can cope with really high temperatures.
so, i'm not sure what fluid(s) would suit your needs....
Old May 29, 2004 | 11:46 PM
OBE1 95Z28's Avatar
Valvoline Synpower Dot 3/4 fluid has a boiling temperature of 500 degrees and is cheap and readily availalbe at most auto stores.
Old May 30, 2004 | 12:27 AM
rskrause's Avatar
Moderator
I haven't been too impressed with Autozones stuff, unless it's a name brand. You can buy OEM rotors for ~$80 a piece. That's what I use with my C5 calipers.
Rich Krause
Old May 31, 2004 | 12:11 PM
CamaroBoy96Z28's Avatar
I also use stock C5 rotors, they are plenty good.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Jazsun
Dec 29, 2014 12:14 PM
