what parts should i get for the 1/4
From: brunswick ohio, small burb south of cleveland
i am finally making some good HP and TQ and am ready to start in on the suspension. except for the tires and rims its all stock. i am leaning toward drag radials (i really dont want to change rims and tires for the track) probably the nitto 270/40 17's but i dont know about the suspension. i see lots of torque arms, LCA some with relocation brackets some without, springs, shocks, poly bushings.... please provide some input as to what would make great track use and drivable street use. both opinion and real world example is appreciated.
david
david
I'd use either BMR or Spohn for these parts:
poly/poly LCAs with brackets
adj. TA
weld in SFCs
pan hard rod
All the other stuff you can pretty much stay away from for the 1/4 mile. Such as sway bars, and shock tower braces.
Hope that helps some
adj. TA
weld in SFCs
pan hard rod
Originally posted by dren70
mike what about springs??
