what coilover to use?
Old Nov 7, 2006 | 12:59 PM
1ss's Avatar
1ss
What set up should I use on my 2000 ss camaro. I am looking at Ground Control's coilover set up with eibock springs???? What else is in the market? Airbags is a bit much on the costly side. Please help!
Old Nov 7, 2006 | 03:50 PM
Spohn Performance sells a modified QA1/HAL setup for the rear:
http://www.spohn.net/category.cfm?categoryid=1203
You could substitute the QA1/HAL's for the front shocks, with whatever springs you want. But the QA1's are an "average" shock at best, for anything other than the 1/4-mile.
What are your goals for the car.... straight line traction, twisties, low rider????
Old Nov 8, 2006 | 04:09 PM
z28racn's Avatar
coil overs
Do you have 315's? I run 315 with no bum stops. i have side to side rubbin issues and I blew a set of koni shocks with eibach springs. I since have moved to the lg motor sports rear coil overs with a very stiff spring rate. so far all has been well. I you plan or road racing i would go with a coil over setup. strano will tell you to run koni adj or dbl adj and a sleev coil over. lg's product has been very stout for me especially in crappy california roads. My friends are verysuprised how well the car handles minus the rubbing and noise from the lower spericle bearing control arms. if you have any more questions e-mail me at robert@adinvestment.net
Old Nov 11, 2006 | 09:25 PM
1ss's Avatar
1ss
I want a bad *** look that will work well on the street. Thanks for the help!
Old Nov 12, 2006 | 06:58 PM
SOMSS's Avatar
Best bang for the buck is Ground control coil overs.
kandied91z
May 19, 2004 09:55 PM
Cmarsh93z
May 3, 2004 04:52 AM
Achilles97
Mar 10, 2004 03:48 PM
Big P
3rd Gen / L98 Engine Tech
Feb 26, 2004 06:52 AM
snorkelface
19
Jan 12, 2004 10:36 AM
