using 2 spring isolators on rear...reduce drop
Old Oct 31, 2006 | 01:58 PM
teke184's Avatar
is it possible...and advisable to use 2 spring issolators on the top of the rear springs to reduce the amount of drop that a set of lowering springs provides?
looking for a mild drop on my car...but worried that most springs will give too much.
i'm thinking even some BMR 1" springs may be too much...but i like the spring rates.
Old Oct 31, 2006 | 02:33 PM
OBE1 95Z28's Avatar
Not sure how you would keep 2 springs isolators in place. You might be able to fabricte a ring to attach to a stock isolator to increase the spacing.
Old Nov 1, 2006 | 06:26 PM
RE AND CHERYL's Avatar
You could always cut a piece of plywood to act as a spacer above the isolator.
Old Nov 1, 2006 | 07:18 PM
Bayer-Z28's Avatar
I've heard that the BMR's sag after a while. One reason I did not get them. I've also HEARD that they ride like crap. -Again, hear-say...
You could prolly fab something up.. Do you have any acess to bulk large pieces of rubber?
From a 1" drop, two spacers would be about an inch, or maybe 3/4"... Try one and see what you think. BTW, THe Eibach's ride nice. But, I think it dropped mine a little more than an inch.
Old Nov 1, 2006 | 07:36 PM
OBE1 95Z28's Avatar
Originally Posted by Bayer-Z28
I've
It would need to be a very hard rubber to do the job.
Old Nov 2, 2006 | 06:23 AM
teke184's Avatar
"THe Eibach's ride nice. But, I think it dropped mine a little more than an inch"
thats why i'm not so keen on them.
i have true duals and i need some clearnce. but i want to reduce fender gap and firm up the ride a bit.
the car gets driven maybe once a week...ride quality isn't a huge issue
Old Nov 2, 2006 | 07:19 AM
NJ-LE's Avatar
Question has anyone tried ...
Has anyone tried replacing the thick, stock rubber isolator with 1/2" heater hose? How much drop did it provide? Was it durable enough? Any drawbacks?
Old Nov 3, 2006 | 06:28 AM
I did. It gave me about an inch drop in the rear. Worked great.
You might just try stock springs with the isolator block removed.
Old Nov 3, 2006 | 07:49 AM
teke184's Avatar
yeah but i also want stiffer...
blkWidow
Sep 6, 2015 05:17 PM
Apr 16, 2015 09:57 AM
NewsBot
Mar 30, 2015 12:40 PM
ChrisFrez
Mar 29, 2015 09:43 PM
