U/L control arm bushings and ball joints
Old Jun 19, 2007 | 01:19 PM
JohnD's Avatar
Which wears out the quickest, upper, lower or is there no difference? Seems like I remember that one was worse but I can't remember which one.
Old Jun 20, 2007 | 03:09 PM
multicar's Avatar
The front lower control bushings, followed by the lower ball joint will be the first to go. Then the upper ball joint, and the upper control arm bushings.
Old Jun 20, 2007 | 05:22 PM
JohnD's Avatar
Thanks. I just picked up a set of 1LE lower control arm bushings on the cheap and looks like they will be the first needed.
Old Jun 21, 2007 | 07:43 AM
multicar's Avatar
No problem. Here's a pic of the LCA vertical bushing after 70k miles of relatively conservative driving and my new 1LE LCA one.
http://www.drutter.zoomshare.com/alb...395200/:album?
With my new setup, it not only handles better, it rides better too. It should have come from the factory like this...IMHO
Doug
Old Jun 21, 2007 | 01:02 PM
jchrisos's Avatar
Where did you get the 1LE bushings? Are they the MOOG replacement parts?
Old Jun 21, 2007 | 03:35 PM
JohnD's Avatar
I bought them on EBAY and they aren't here yet so I don't really know who made them or if they are GM new/old stock. Does GM even make them anymore? I know they quit making the 1LE springs because I tried to buy some new and finally managed to find somebody who had a set they wanted to sell.
Old Jun 22, 2007 | 08:57 AM
jchrisos's Avatar
Let me know how they work out. I am looking for new bushings and want to get the 1LE bushings. I'd be interested to hear how easy/hard it is to press out the old and press in the new ones.
Old Jun 28, 2007 | 07:36 AM
JohnD's Avatar
They finally came in and are marked "Harris" so I guess they are not a Moog part. I think they are the real deal as the rubber is quite hard. I won't be installing for a while so the jury isn't in on how they work yet.
Old Jun 28, 2007 | 12:31 PM
jchrisos's Avatar
Well good luck once they're on!
Bobczar
Oct 23, 2015 11:22 AM
R@mpage
Apr 20, 2015 10:02 AM
Apr 16, 2015 09:57 AM
KYWes
Apr 3, 2015 07:59 PM
dbrockma
Feb 16, 2015 02:56 PM
