Tubular or Boxed LCA's?
Old Mar 21, 2006 | 08:35 AM
94Zpower's Avatar
I am looking into getting some LCA's and wa wonder which of the two available types woudl be best for a street car that sees the track a few times a summer, and why one is better t han the other?
Thanks!.
Old Mar 21, 2006 | 09:27 AM
95LT1conv's Avatar
Re: Tubular or Boxed LCA's?
i posted the sme question a few days ago. heres what i was told. the boxed lcas are better for drag, tubular for street use. i was also told if i use the tubular lcas, to get them with a poly/rod end combo
Old Mar 21, 2006 | 09:41 AM
JakeRobb's Avatar
Super Moderator
Yup. For a mostly-street-driven car that sees the trac occasionaly, you'll want tubular components, either with poly/poly or combo ends. The combo end will be a little tighter (harsher) and will create some additional vibration in the car. Typically, the type of person that's doing these mods won't be bothered by those things, so we tend to recommend combo pieces.
If ride quality is really important to you, you might want to go with poly/poly ends.
Old Mar 21, 2006 | 10:27 AM
Odd.... my Spohn tubulars work fairly well for drag use. They work just as well as the box-section Just Suspension LCA's they replaced, and weigh a lot less. And they allow the use of spherical rod ends.
The same Spohn tubulars pushed this 3,525# car to 8.60@160+mph, with a 1.30 60-ft time. I'd say that would indicate that tubulars are just fine for "drag". Why would you want the added weight of a box-section arm?
Old Mar 21, 2006 | 11:01 AM
95LT1conv's Avatar
is it true tha the poly/poly ends will bind causing diminished handling ability?
Old Mar 21, 2006 | 11:20 AM
hotpart's Avatar
Former Vendor
Round tube is actually stronger/stiffer than square tube. The only reason some companies are advertising their square or rectangular being stronger than their round tube is the pure size difference of the material they are using. I believe some companies are using 1 1/4", 1 1/2", or 1 5/8” round versus the square being upwards of 1 1/2" x 3". If you take our control arms for example, they are made from 1.75" round tube. This round tubing will be stronger and lighter than the same 1.75" square tube which by the way both are overkill with how the lower control arms are loaded. What ever you do don’t waste your money on chrome moly arms unless you can get proof that they have been stress relieved and heat treated after welding.
Old Mar 21, 2006 | 02:24 PM
OBE1 95Z28's Avatar
Poly/poly will cause the rear suspension to bind while cornering. I run poly/sperical joint with minimal noise/vibration transferred to the body.
Old Mar 21, 2006 | 03:07 PM
94Zpower's Avatar
so what is the best combo for my applictaion?
Old Mar 21, 2006 | 04:07 PM
Camarocracy's Avatar
What ever fits your budget.
Old Mar 21, 2006 | 07:56 PM
94Zpower's Avatar
As far as LCA's go budget isnt much of a problem because even thebest LCA's are relativly inexpensive , I basically want whats best for the use that my car is going to see, comfort and performance as much as possible anyways lol.
polly bushings are a little more harsh and noisier than rubber but do they actually cause you supension to bind as mentioned above to the point that it will cause problems during daily driving? I guess thats what my question really is at this point.
Old Mar 22, 2006 | 07:16 PM
ttop1986's Avatar
taken from bmr fabrications site...
"Which is better, tubular or boxed control arms?"
This has to be our most commonly asked question. We personally feel that either design is equally as strong for the load that the F-body chassis places on them. Because the F-body uses a control arm/torque-arm combination, very little lateral loading is placed on the control arms themselves. The torque-arm takes the lateral loading while the control arms are subjected mainly to a "compression" loading as the rear tries to push them forward into the chassis under acceleration. While an excessive lateral load would dictate the use of stronger(laterally) rectangular tubing, compression loading is much easier to handle and round tubing(of appropriate size)is more than sufficient. Bottom line: if you are an overkill nut and are willing to spend a little more then go with the boxed design, otherwise save a little money and get the tubular arms.
When i do mine, im going with tubular.
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
karpetcm
Sep 29, 2015 10:08 AM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
