Tubular A-arms install
Old Jul 1, 2005 | 08:25 PM
Valkyn71's Avatar
Brakes are starting to go on the car, so i purchased everything i need to do an LS1 brake swap. Figured while i was at it i might as well swap in the profab Kmember and A arms ive had for a few months.
The A-arms have rod ends, like these:
http://www.profabracing.homestead.co...ower_A-Arm.jpg
My question is how do i know how the rod ends should be adjusted? Just measure the stock A-arms and try to adjust them as close to stock length as possible? Also are the rod ends really noisy durring daily driving?
Old Jul 3, 2005 | 05:30 PM
Valkyn71's Avatar
Re: Tubular A-arms install
Someone must know...also will the tubular K-member lower the front end any?
Old Jul 3, 2005 | 07:54 PM
Ryan94ZA4's Avatar
According to my BMR instructions, you basically want to get the rod ends in approximately the same location as your factory control arm has. Then, put it in the K member and get to an alignment shop before you do any driving.
Ryan
Nov 18, 2023 07:21 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
87Aerocoupe
Jan 10, 2015 07:27 PM
