Traction Problems Please Help
Old Feb 10, 2005 | 05:29 PM
96camaroz28lt4's Avatar
I am having bad traction problems. I have new transmission mount and the torsion bar is nice and tite and it's just when I launch or take off hard the car will spin at first then after it spins I guess it tries to hook up but all it does is just bounce the back tires really bad and it shakes the whole car. Any suggestions?
Old Feb 10, 2005 | 05:44 PM
jchevy's Avatar
Re: Traction Problems Please Help
Its wheel hop from the car being dropped 3". Not sure how to fix it. Maybe LCA's?
Old Feb 10, 2005 | 06:04 PM
1racerdude's Avatar
Weld anti-squat brackets on rear end at LCA mounting point.
Old Feb 10, 2005 | 10:32 PM
redcamaroz28's Avatar
Get the LCA relocation brackets welded in. Also some subframes might help a little.
Old Feb 10, 2005 | 11:40 PM
So what exactly do I need, any links?
Old Feb 10, 2005 | 11:55 PM
1racerdude's Avatar
No--- All you need is the brackets and get them welded on.
You can get them from Thunder Racing,Global West,Moser, or any good suspension maker.
Old Feb 10, 2005 | 11:59 PM
Alright I found some tubular Pro-Fab LCA's but will they bolt up? Or will I need brackets, if I need brackets then where can I find them.
Old Feb 11, 2005 | 12:01 AM
1racerdude's Avatar
You can run the factory LCA's. All you need is the brackets.
Go to Global West sight and get an idea what they are. Anti-Squat brackets.
Old Feb 11, 2005 | 12:09 AM
what's the site and where exactly do they relocate to?
Old Feb 11, 2005 | 12:14 AM
1racerdude's Avatar
The brackets weld to the ones the LCA's are in now. They extend down to regain the angle on the LCA's when you lowered the car. They should be pointed up in the front and bet yours ain't.
See previous post on sights.
Old Feb 11, 2005 | 12:18 AM
But there's no link you just say Global west site... so is that globalwest.com or what? So it should be pointed at an agle like facing up then the rear down?
Old Feb 11, 2005 | 12:30 AM
http://cgi.ebay.com/ebaymotors/ws/eB...category=33583 I found some but they are 59.95 Is that a good price. I was wondering why would you lower the back of the control arm. Wouldn't that cause it to bounce more and would this lower the axle? I don't see how it straighten the axles up.
Old Feb 11, 2005 | 12:43 AM
1racerdude's Avatar
That's a good price.
Your suspension geometry in the back is all out of wack. Look at a stock one and see. It is to complicated to explain the angles and how one angle has to coincide with the torque arm to get the instant center right. The LCA angle has to work with the TA angle to get you there. If the LCA's are pointed down in the front that won't work. A projected line of the angle of the LCA's has to intersect the TA and with the front level or pointed down they never do.
They don't straighten anything up they change the angle from front down to front up on the LCA's.
Old Feb 11, 2005 | 01:18 AM
Well it says that if you lower your car the rearend sits higher than you TA and if you use these it will even them out and that's what I meant by lowering the rear.
Old Feb 11, 2005 | 01:23 AM
1racerdude's Avatar
OooooK
