Is there something wrong with my caliper?
Old Aug 3, 2006 | 09:02 PM
KillerTA's Avatar
My front right brake pads have worn all the way down and need to be replaced but the front left side looks almost like new.
I bought the car with 92000 miles a year ago and it now has 101000 miles. When I it, I believe the pads were almost like new (like the drivers side is) but I don't remember for sure.
That brake (passenger front) has a decent amount of pulsation in it because the rotor was warped when I bought the car, although it seems to have evened out a little bit over the 9000 miles I drove it. I'm not sure if it was just that one or if there were others that were/are warped or not.
The car might pull just slightly to the right when braking very hard but I can't say that I realy ever notice it, and it drives perfectly straight on the roads. I don't believe there is any drag on that wheel from the brake. There are no leaks on the caliper either and the tires have even wear.
Do you think the left front pads are worn out is because of the warped rotor eating them up or because of something else? Should I go ahead and replace the caliper? Do I need to replace the drivers side too?
Old Aug 3, 2006 | 11:21 PM
Red_94Formula's Avatar
Re: Is there something wrong with my caliper?
Check out the caliper pins. If they are dry and not greased up thats prob the problem. and LS1's brakes love to get warped when heavily used. I would get new rotors or uprade to something bigger.
Old Aug 4, 2006 | 10:12 AM
Greed4Speed's Avatar
Could also be a sticking piston in that one caliper
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
