Taking car in for 8pt, what else?
Old Oct 9, 2006 | 03:11 PM
RacerTim's Avatar
I have a 94 camaro with a 355 and 250 shot of nitrous. I am dropping the car off in the next couple days to get the 8pt bar installed, what else should I get done while I am there? I removed the HVAC system, so I am going to have him fab something up to cover the monster whole in my firewall. I dont have the seats in yet, so I am going to wait to have them installed. Should I have sub frame connectors installed too? Or wait for them, or how bad do I acually need them? Let me know whatelse. I hope to have the car running 10s by the end of next season.
Old Oct 9, 2006 | 05:08 PM
OBE1 95Z28's Avatar
Re: Taking car in for 8pt, what else?
Weld in a set of LCA relocation brackets.
Old Oct 10, 2006 | 04:17 AM
Eric@Victory Racing's Avatar
I would have subframe connectors installed too. Is there any reason why you are having a 8pt cage installed instead of a 10pt? Below I have listed some of the other things you might want to look into if you plan on running 10's at the track.
SFI 18.1 harmonic balancer mandatory
Aftermarket axles and axle retention device mandatory
SFI 4.1 spec transmission shield required on automatic trans cars
Rollcage required for convertibles or cars running faster than 135.
Rollbar is still OK for full bodied cars with stock firewall, floor, and body.
SFI 29.1 flexplate if car runs 135mph
Flywheel and clutch must be SFI 1.1 or1.2
Flywheel shield meeting SFI spec 6.1, 6.2, 6.3, or 9.1 mandatory.
Driveshaft loop mandatory reguardless of tire type.
SFI 16.1 5 point restraint mandatory, updated every 2 years.
SFI 3.2a/1 fire jacket.
Helmet must be Snell 95, K98, 2000, 2005, SFI 31.1, 31.2, 31.1a, 31.2a, 31.1/2005, 41.1, 41.1a, 41.2, 41.2a, 41.1/2005. SFI 31.x = SA SFI 41.x = M
NHRA only. All non-OEM supercharged, non-OEM turbocharged, and nitrous cars need SFI 3.2a/1 fire jacket
Old Oct 10, 2006 | 09:44 AM
RacerTim's Avatar
I see.... it wouldnt be that unheard of to run 135mph and still be in the mid 10s. I bought the 8pt kit from Summit, I just ask him if he can add the top hoop and front bars then.
Old Oct 10, 2006 | 06:51 PM
ABA383's Avatar
In keeping with the 5 point harness theme, something often overlooked until you're installing the belts is the bracket for the "crotch" or "sub" belt...
--Alan
calaban
May 18, 2020 06:43 PM
Noenav
Mar 1, 2019 07:38 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
ChrisFrez
Dec 15, 2014 03:09 PM
USAirman93
Nov 24, 2014 03:37 PM
