t top conversion?
Old Dec 12, 2004 | 03:15 PM
nasty stroker's Avatar
t top conversion?
I saw a add on ebay for t top coversion. Ive got a 95 z and id like to put t's in it. can this be done? I emailed the guy and he said sure its done everyday. Ive got a freind with a wrecked bird and it has t's i can get for cheap. Has anyone out there done it?
Old Dec 12, 2004 | 08:27 PM
TransAm2k4's Avatar
Re: t top conversion?
It should be cutting where the t's goes but it must be a job well done or the car is going to loose a lot of it's rigidity and it might leak in rains.
Old Dec 13, 2004 | 06:25 AM
the guy said you have to unbolt the whole roof and that all cars come thru with the t bar already up there. i dont know i just figured someone out there has done it.
Old Dec 13, 2004 | 01:01 PM
No "bolts" involved. The coupe roof is plastic. You cut the front of the panel off with a grinding wheel or a saw. Then there is a sheet metal structural member on each side, above the door opening that needs to be cut out. As you noted, the "t" member is already there.
Go to this website:
http://dw-zone.com/
Click on "My 94 Formula....", scroll down to "Winter 2000/2001", and click on the "install t-top" link. Excellent photos and narrative.
Old Dec 13, 2004 | 01:43 PM
MustangEater82's Avatar
yeah you do have to cut but ~80% of the factory t-top stuff is on a a hardtop car. Holes for the center trim bar, most of the lip for the weatherstripping, etc...
Old Dec 13, 2004 | 08:29 PM
wow thanks. i would have never gotten thru that without some instructions. So would you do it again? was it worth it? I can get the whole set up out of a wrecked car for 100 bucks. Im a jack of all trades master of none do you think it was a hard job?
NewsBot
Dec 3, 2014 12:30 PM
slocody
Feb 10, 2003 01:04 PM
FilledWithFurySS
Jul 26, 2002 02:00 PM
