Sway Bars?
Old Mar 18, 2007 | 03:56 PM
Ucantcme57's Avatar
Sway Bars?
Are bigger always better? Is solid better than not? Is chrome moly a must?
Old Mar 18, 2007 | 04:48 PM
JimboManJones's Avatar
For the front, bigger is better, hollow is better then solid, solids only marginally stiffer and alot heavier, chromeoly doesn't make a difference.
Old Mar 18, 2007 | 06:44 PM
OBE1 95Z28's Avatar
Sway bars work best with the rear and front working together. Most people find 35mm front and 21 or 22mm rear to work well together. The sway bar is a torsion spring, therefore they're not made out of chrome moly as that's not an ideal spring material.
Old Mar 18, 2007 | 09:44 PM
Greed4Speed's Avatar
Spohn does.
http://www.spohn.net/product.cfm?productid=1376
Old Mar 18, 2007 | 09:46 PM
OBE1 95Z28's Avatar
You learn something every day
Old Mar 18, 2007 | 11:45 PM
What are you using the car for? The answer is going to be different on a car intended to go around corners, than for one intended to go in a straight line, 1/4-mile at a time.
Old Mar 19, 2007 | 09:35 AM
Ucantcme57's Avatar
I want the car to do everything.. So the best of both worlds would be........?
Old Mar 19, 2007 | 09:51 AM
OBE1 95Z28's Avatar
A corner carving suspension and a drag racing suspension don't really mix. Corner carving calls for a stiff suspension to minimize weight transfer during cornering; drag racing wants weight transfer to the rear during launching. Years past I wanted both. I installed a set of QA1 12 way adjustable shocks on all 4 corners thinking I could dial in the suspension I wanted for that day's driving adventure. These shocks are very poor performers for corner carving. Also for corner carving you'll want a larger front sway bar; for drag racing you want want a sway bar at all.
Old Mar 19, 2007 | 12:14 PM
Ucantcme57's Avatar
So your sayign that KYB gas adjust shocks are worthless????
http://cgi.ebay.com/ebaymotors/KYB-A...QQcmdZViewItem
Old Mar 19, 2007 | 12:32 PM
OBE1 95Z28's Avatar
I have no experience with KYB. Adjustable shocks can be great, i.e. the Koni SA shocks, but they are focused on great corner carving, not corner carving and optimized drag racing.
Old Mar 22, 2007 | 12:06 PM
Sam Strano's Avatar
Pretty much.... yes.
Old Mar 22, 2007 | 12:14 PM
danhr's Avatar
I am going to disagree with this statement
they make a damn good paper weight
Old Mar 22, 2007 | 03:26 PM
Or a crude weapon.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
force10
Jul 30, 2015 04:56 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
