Sway bar bushing lube question...
Re: Sway bar bushing lube question...
Most people use a petroleum based grease but Jeg's (I think) sells a specific lubricant just for poly bushings. I hear normal petroleum products can break-down poly bushings. It should work well for rubber bushings also.
You'll probably find that the poly bushings will get worn from suspension movement to the point where they should be replaced before petroleum based lubes will break it down. Now, if the car is a garage queen, you may have to worry about it.
RUENUF
Mar 13, 2016 03:37 PM
. All rubber bushings as I understand it from the factory. Will find out next week!
