swapping from drums to disc on 10 bolt!?
Old Aug 27, 2005 | 07:45 PM
turbo_Z's Avatar
I can get a good deal on a 3.73 rear however it has drum brakes which I dont want so Id have to take my brakes off and swap them. I need to know if its a simple bolt on deal or if I have to modify anything. Basically can I simply remove the disks and drums and swap them or do the axles need to be changed as well? Thanks
Old Aug 27, 2005 | 09:32 PM
Re: swapping from drums to disc on 10 bolt!?
It depends on what it came out of.
Old Aug 27, 2005 | 10:14 PM
respectirocz's Avatar
i havent tried changing a drum brake 10 bolt to a disc brake set up
would it be easier to take the differential out of the drum brake set up and throw it in the disc brake rear?
Old Aug 28, 2005 | 04:11 AM
Z95m6's Avatar
Shoebox i believe the drum brake car is the a 96 V6 and the disk brake car is a 97z28.
Old Aug 28, 2005 | 08:09 AM
Someone put 3.73s in a V6 car? Then I don't see there being a problem in swapping over the brakes as long as they are not mixed TCS and non-TCS.
Old Aug 28, 2005 | 12:42 PM
Z95m6's Avatar
Yeah, it probably sounds funny that the 3.73's were in a V6 car but the car was in the process of becoming a LT1 car.
Old Aug 28, 2005 | 12:55 PM
turbo_Z's Avatar
Actually there was an LS1 in it.
Victor Lamb
Aug 26, 2017 02:52 PM
maybe2fast
Mar 16, 2015 09:45 AM
grabbem88
Feb 17, 2015 07:49 AM
ddr698
Jan 9, 2015 10:05 AM
Cam's maro
Jan 8, 2015 05:01 AM
