Suspension Upgrades
Old Apr 23, 2004 | 05:23 PM
ArizonaZ's Avatar
Suspension Upgrades
I am planning on swapping out my 2.73's for some 3.73's, but am pretty sure the suspension is really gonna need to be beefed up to take it and improve my times at the track. I have subframe conectors already, but can't decide what to do next. Was thinking rear Lower control arms first and see from there. What do you think?
Old Apr 23, 2004 | 05:26 PM
Terran2k's Avatar
lca and relocation brackets would help transfer the power to the ground.
Old Apr 23, 2004 | 05:28 PM
ArizonaZ's Avatar
I see your running BMR'S, how do you like those. Also, would you go adjustable or not?
Pasky's Avatar
LCA relocation brackets and new LCA's will help you the most. Also consider getting rid of the stock tourque arm so it can be placed on the transmission crossmember to get the force off the tail shaft of your transmission. I really have to recommend spohn.net. I use thier products, I personally have thier wonderbar, tourque arm, and t-56 retrofit crossmember. Thier welds are great and they use high quality material. Not to mention thier customer service is great.
Old Apr 23, 2004 | 06:03 PM
ArizonaZ's Avatar
Do the relocation brackets reallt make that big of a difference?
Old Apr 23, 2004 | 06:40 PM
americanmusscle's Avatar
They help if your car is lowered. They help with the center of your something I forget. Also a panhard rod, but the torque arm is a great mod. You will hook better out of the hole.
Old Apr 23, 2004 | 07:22 PM
Pasky's Avatar
They have an even greater effect if your car isn't lowered.
Old Apr 23, 2004 | 09:38 PM
ArizonaZ's Avatar
is bmr the only company that makes those?
Old Apr 23, 2004 | 11:11 PM
Somnambulist's Avatar
I always heard that Spohn was the way to go as far as torque arms go...but I'm sure BMR makes a great product as well!
97blackformula
Aug 27, 2015 06:02 PM
97SSdude
Aug 21, 2015 09:36 AM
force10
Jul 30, 2015 04:56 PM
realistyc
Jul 28, 2015 07:32 PM
