Subframe connectors pics?
Old May 27, 2006 | 03:43 PM
supercharged87's Avatar
Does anyone have any pictures of subframe connectors installed underneath their car? If so could you post them and what kind they are? I'm in the market for a set and I just wanted to see what they looked like on the car being that every picture of I find is just of the subframe connector itself. Thanks alot in advance for any help given.
Old May 27, 2006 | 07:09 PM
MyShibbyZ28's Avatar
Re: Subframe connectors pics?
http://images.google.com/imgres?imgu...l%3Den%26lr%3D
Google works.
Old May 28, 2006 | 01:22 PM
teke184's Avatar
BMR boxed weld ins....made a great improvement.
some are during installation so the welds look bad. some are after with the welds cleaned up and painted.
the last one is to show the clearance. BMR says the boxed reduce clearance by 3/4"...but with my ground effects...it didn't make a difference...the gfx are as low as the SFC.
Old May 28, 2006 | 02:17 PM
Thanks alot for the help. I appreciate it.
Old May 30, 2006 | 01:57 AM
87lt1rx7's Avatar
I am going to be installing a set of bolt on slp dd style sfc's. does anyone have pictures of those installed?
Old May 30, 2006 | 08:34 AM
teke184's Avatar
suggestion...
right after you bolt them in...have them welded.
over time the bolt holes will elongate and will not provide the support you need.
Old Jun 1, 2006 | 12:08 PM
camaro1fastz28's Avatar
i used the round one and they dont affect the ground clearence the best inprovement i have done
HOFFICER
Apr 6, 2020 10:36 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
R@mpage
Apr 20, 2015 10:02 AM
